RBL's
Posted: 12 Feb 2014 17:53
by Gspearson
I am very new to this project and familiar with MailScanner as it is powering the Mail Filtering of the Mailing List Server (Sympa) for our organization. With the work that has been done on this project, what is the easiest way to add a RBL list to the project that would be Update Safe. I have learned working on other projects to find ways that when the core software gets updated that my changes do not get wiped out.
I would like to use only 1 BlackList which happens to be barracudacentral.org
Re: RBL's
Posted: 12 Feb 2014 21:50
Create a new cf file in /etc/mail/spamassassin
Such as barracuda.cf
Add your RBL in this file.
That way, when Spamassassin gets upgraded, and files get modified or overwritten, you will have your own config file.
Re: RBL's
Posted: 16 Mar 2014 15:32
by micha0808
How is the Syntax in the .cf file?
Can you make an example?
Thanx a Lot!
Re: RBL's
Posted: 18 Mar 2014 22:18
Actually, it may be better to specify an RBL in postfix and stop the email from entering the system...
Here's the default in /etc/postfix/main.cf for zen.spamhaus.org...
smtpd_client_restrictions = permit_sasl_authenticated, reject_rbl_client zen.spamhaus.org
Re: RBL's
Posted: 21 Mar 2014 06:46
by micha0808
I do not want to delete the mail immediately. I want to work with a score.
This is my Code from barracuda.cf:
header RCVD_IN_BRBL                     eval:check_rbl('brbl-lastexternal', 'b.barracudacentral.org.', '127.0.0.2')
describe RCVD_IN_BRBL                   Received via relay listed in Barracuda RBL
score RCVD_IN_BRBL                      3.0
tflags RCVD_IN_BRBL                     net
I Dont see a Match in the Spam Report.
How can I test the rule or activate the rule? Is the code correct?
Thank you for your help!
Re: RBL's
Posted: 22 Mar 2014 00:22
Actually, I see an active rule in spamassassin for Barracuda Central already:
72_active.cf:
header RCVD_IN_BRBL_LASTEXT   eval:check_rbl('brbl-lastexternal','bb.barracudacentral.org')
tflags RCVD_IN_BRBL_LASTEXT   net
