Could not open file
Posted: 18 May 2021 14:38
Hello and thank you for all the fine work you have done over the years
I have a lot of messages like this in E.F.A. 4
May 18 00:34:14 mx03 MailScanner[14583]: Could not open file +</var/spool/MailScanner/milterout/temp-21076-4FkXSw63ryz4xJn0: No such file or directory
May 18 08:09:01 mx03 MailScanner[24307]: Could not open file +</var/spool/MailScanner/milterout/4FkkYn1LZsz5C1T: No such file or directory
May 18 08:15:08 mx03 MailScanner[4271]: Could not open file +</var/spool/MailScanner/milterout/temp-15181-4FkkcY2HwRz4xZxb: No such file or directory
May 18 08:15:08 mx03 MailScanner[15181]: Could not open file +</var/spool/MailScanner/milterout/4Fkkhr0Mmvz5C1d: No such file or directory
May 18 09:03:58 mx03 MailScanner[25134]: Could not open file +</var/spool/MailScanner/milterout/4Fklmp0pFKz5C1t: No such file or directory
for a specific queueid the log is like this
[root@mx03 ~]# grep 4FkRty6Txbz0pDl /var/log/maillog
May 17 21:07:54 mx03 MailScanner[8443]: Requeue: 4FkRts6QNHz4xJn3 to 4FkRty6Txbz0pDl
May 17 21:07:55 mx03 MailScanner[4439]: Could not open file +</var/spool/MailScanner/milterout/4FkRty6Txbz0pDl: No such file or directory
May 17 21:07:55 mx03 MailScanner[4439]: Cannot open /var/spool/MailScanner/milterout/4FkRty6Txbz0pDl for relaying, will try again later
[root@mx03 ~]# grep 4FkRts6QNHz4xJn3 /var/log/maillog
May 17 21:07:49 mx03 postfix/smtpd[5158]: 4FkRts6QNHz4xJn3: client=xxxxxxxx.gr[xxx.xxx.xxx.xxx]
May 17 21:07:49 mx03 postfix/cleanup[5178]: 4FkRts6QNHz4xJn3: message-id=<CAB1Nd4f=WG9RJcBoxNOkcM07nGOnEmVNMovP5qKbUZg4wjPiUQ@xxxx.xxxxx.com>
May 17 21:07:50 mx03 opendkim[9169]: 4FkRts6QNHz4xJn3: XXXXXXXX.gr [xxx.xxx.xxx.xxx] not internal
May 17 21:07:50 mx03 opendkim[9169]: 4FkRts6QNHz4xJn3: not authenticated
May 17 21:07:50 mx03 opendkim[9169]: 4FkRts6QNHz4xJn3: DKIM verification successful
May 17 21:07:50 mx03 opendmarc[9160]: 4FkRts6QNHz4xJn3: SPF(mailfrom): xxxxxx@xxxxx.gr pass
May 17 21:07:50 mx03 opendmarc[9160]: 4FkRts6QNHz4xJn3: xxxxx.gr pass
May 17 21:07:52 mx03 postfix/cleanup[5178]: 4FkRts6QNHz4xJn3: milter-discard: END-OF-MESSAGE from xxxxxxxxx.gr[XXX.XX.XX.XXX]: milter triggers DISCARD action; from=<SRS0=wVVY=KM=xxxxxxx.gr=xxxxxxx@xxxxxx.gr> to=<xxxxxxx@xxxxxxx.gr> proto=ESMTP helo=<xxxxxxxx.gr>
May 17 21:07:54 mx03 MailScanner[8443]: <A> tag found in message 4FkRts6QNHz4xJn3 from xxxxxx@xxxxx.gr
May 17 21:07:54 mx03 MailScanner[8443]: Message 4FkRts6QNHz4xJn3 from XXX.XXX.XXX.XXX ( xxxxxx@xxxxx.gr) to med.uoc.gr is too big for spam checks (2306499 > 2048000 bytes)
May 17 21:07:55 mx03 MailScanner[2770]: Could not open file +</var/spool/MailScanner/milterout/temp-8443-4FkRts6QNHz4xJn3: No such file or directory
May 17 21:07:55 mx03 MailScanner[2770]: Cannot open /var/spool/MailScanner/milterout/temp-8443-4FkRts6QNHz4xJn3 for relaying, will try again later
May 17 21:07:55 mx03 MailScanner[8443]: MailWatch: Logging message 4FkRts6QNHz4xJn3 to SQL
May 17 21:07:55 mx03 MailScanner[14561]: MailWatch: 4FkRts6QNHz4xJn3: Logged to MailWatch SQL
This is something that does not happen in E.F.A. 3
Let me note here that I have a high volume mail infrastructure this this usualy happens under stress, one the other hand this is not an issue on EFA 3
and with "smaller" machines.
Any thoughts?
Any thoughts?
