Error at boot when signatures enabled
sem
Post by sem »
Added HTML and text signature. No signatures being applied to mail. This error reported at boot:
Could not read file /etc/MailScanner/signatures/domains/html/1.html at /usr/share/MailScanner/MailScanner/Config.pm line 2864 Syntax error in line 1 of ruleset file inlinehtmlsig at /usr/share/MailScanner/MailScanner/Config.pm line 2811
Could not read file /etc/MailScanner/signatures/domains/html/2.html at /usr/share/MailScanner/MailScanner/Config.pm line 2864 Syntax error in line 2 of ruleset file inlinehtmlsig at /usr/share/MailScanner/MailScanner/Config.pm line 2811
Could not read file /etc/MailScanner/signatures/domains/html/3.html at /usr/share/MailScanner/MailScanner/Config.pm line 2864 Syntax error in line 3 of ruleset file inlinehtmlsig at /usr/share/MailScanner/MailScanner/Config.pm line 2811 Found syntax errors in database ruleset inlinehtmlsig at /usr/share/MailScanner/MailScanner/Config.pm line 2626
sem.
darky83
Site Admin
Re: Error at boot when signatures enabled
Post by darky83 »
Do the files: /etc/MailScanner/signatures/domains/html/x.html actually exist?
sem
Post by sem »
No. No files.
darky83
Site Admin
Post by darky83 »
I will test this some further,
Baruwa doesn't create the directory's, but if you create the dir's yourself I get a error when creating new signatures:
Task generate-domain-signature-files[fb52210b-797d-4bdc-afe9-4702e5e09ec4] raised exception: IndexError('list index out of range',)
Traceback (most recent call last):
  File "/usr/lib/pymodules/python2.6/celery/execute/trace.py", line 34, in trace
    return cls(states.SUCCESS, retval=fun(*args, **kwargs))
  File "/usr/lib/pymodules/python2.6/celery/task/base.py", line 241, in __call__
    return self.run(*args, **kwargs)
  File "/usr/lib/pymodules/python2.6/baruwa/config/tasks.py", line 207, in run
    update_ms_serial(logger)
  File "/usr/lib/pymodules/python2.6/baruwa/config/tasks.py", line 51, in update_ms_serial
    )[0]
  File "/usr/lib/pymodules/python2.6/django/db/models/query.py", line 189, in __getitem__
    return list(qs)[0]
IndexError: list index out of range
Not sure whats the reason right now.
cam
Post by cam »
Have we determined how to implement domain signatures successfully yet or is this still a work in progress?
darky83
Site Admin
Post by darky83 »
Still a work in progress,
I hope to have this in 0.4 seems to be not really stable enough still trying to figure out why.
datopdog
Post by datopdog »
That error is because you either do not have a scanner host configured or the one configured does not match what is returned by the hostname command
