E.F.A. 3.0.0.2 update released
Posted: 06 Feb 2014 10:28
by darky83
Due to an small bug we created with the 3.0.0.1 update we have released the 3.0.0.2 update today.
The following issues have been fixed in 3.0.0.2:
  • Correct db settings in learn-msg.cgi
We encourage everyone to update.
If you have auto update enabled your system will automatically update to this new release.
If you have auto update disabled you will need to run the update command manually:
1) login to your box with ssh
2) press ’1′ to get an shell
3) type:
You can download the latest VM image version from http://efa-project.org/download
