Spam FQDN Report Links
Posted: 25 Feb 2021 23:13
by barbours
I am having an issue with the links in the spam reports. In the report sent to the user, the link is no longer to the fully qualified domain name. It is being sent with the name of the server only, example "servername" instead of "servername.example.com. The link to the message following the name seems right, but without the FQDN it doesn't go anywhere when the user clicks on it.
I have reviewed the conf.php but don't see anything specific that stands out. Hoping you can help.
sb
Re: Spam FQDN Report Links
Posted: 04 Mar 2021 17:36
by barbours
I started digging around and looking at the various scripts that involved reporting spam, etc. I noticed that most of them had the $hostname variable in them. So, I decided to look at the /etc/hostname file and it had only the name of the server and not the fully qualified domain name. I changed the /etc/hostname to include the FQDN and rebooted. The link to view the quarantined name is now functional again.
This also cleared up a warning in the delivery of email. The SMTP banner is now correct. Problem solved.
