Script : generate_uriskip
Post by nicola.piazzi »
To reduce dns queryes can be useful to use verb uridnsbl_skip_domain to skip uribl search for safe domains
This is an example of .cf lines to use :
uridnsbl_skip_domain 3m.com abb.com acer.com ac.ma adobe.com adp.com aermec.com al.com amazon.ca amazon.com
uridnsbl_skip_domain anpdm.com apache.org apc.com apple.com avg.com avm.de avnet.com aweber.com azureedge.net blat.net
I made a script that examine all mail quarantine folder and search in each file for domains , then it pass to public whitelist and create automatically a .cf file to exclude your safe domains
This is very simple and can be in cron
generate.uriskip.zip
(1.41 KiB) Downloaded 547 times
Re: Script : generate_uriskip
Another fine script from nicola.piazzi!
I need to gather all these up and make them options, a Nicola Settings section :D
updated version, requires install ripmime command but is more efficient in url scanning
(1.71 KiB) Downloaded 563 times
keysteal
Post by keysteal »
Hi, I don't understand if the .cf created by this script is automatic included in spamassasin's check. If not, can you explain me how can I use the .cf created ? Thx
