Error on fresh install
andreluizpr
Post by andreluizpr » 18 Feb 2021 18:35
Hello all,
I just created a LightSail instance on AWS with CentOS 7 minimal. I updated the OS, installed the NetworkManager package and restarted the server.
Then I ran the following command: curl -sSL https://install.efa-project.org | bash
No errors happened and I restarted the machine. When reconnecting to the server, I started the first configuration and did it as I always did on other occasions. However when I finished and the system started to perform the tasks, I saw the following errors:
[eFa] - Starting MariaDB and Configuring
Dropping the database is potentially a very bad thing to do.
Any data stored in the database will be destroyed.
Do you really want to drop the 'test' database [y/N] Database "test" dropped
ERROR 1064 (42000) at line 20: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'firstseen TIMESTAMP NOT NULL DEFAULT CURRENT_TIMESTAMP,
lastsent TIMESTAMP NOT ' at line 11
[eFa] - Configure timezone
[eFa] - Configuring razor
nextserver: Bootstrap discovery failed. Giving up.
chmod: cannot access ‘/var/spool/postfix/.razor/identity-*’: No such file or directory
The installation was aborted. Is there any way to fix this? Is it possible to configure another version (like stable) that is not showing configuration errors? Any other references to follow with the installation?
Andre
Re: Error on fresh install
Post by shawniverson » 20 Feb 2021 00:22
One of our mirrors must be behind. These issues have been fixed grrr...
jobe
Post by jobe » 22 Feb 2021 17:33
Hi, I am trying to install EFA 4.0 and I have just received the same error. What do I do now? Can I re-launch the installation wizard (how?) and see if it connects to a working mirror?
Post by shawniverson » 22 Feb 2021 23:54
Working on it. You can work around the issue for now by ensuring that NetworkManager is enabled prior to building.
sudo systemctl enable NetworkManager
1an3
Post by 1an3 » 07 May 2021 13:10
With apologies for replying to a thread from a few months ago, but I've just hit this same issue.
Attempted the workaround with the command "sudo systemctl enable NetworkManager" then reboot and login as root to start the config off again, but it still fails.
Am I doing something wrong?
Ian
1an3
Post by 1an3 » 07 May 2021 13:45
Further info - I reverted my snap to the server-built stage.
ran sudo systemctl enable NetworkManager
install eFa "sudo su" "curl -sSL https://install.efa-project.org | bash"
reboot
login as root, run the configure. same error
chmod: cannot access '/var/spool/postfix/.razor/identity-*' : no such file or directory
Post by shawniverson » 09 May 2021 23:35
Are you blocking DNS, by chance?
1an3
Post by 1an3 » 11 May 2021 09:06
Don't think so?
nslookup www.google.com 8.8.8.8
returns 142.250.178.3 etc etc
1an3
Post by 1an3 » 13 May 2021 15:17
shawniverson wrote:
09 May 2021 23:35
Confirmed not blocking DNS - have allowed $server to be able to talk to the outside to world to everywhere on everything. Checked FW logs and it's talking DNS so it's not that
Yesterday I seemed to get further but today I am stuck at the Razor error again
My box is Centos7, with only webmin installed. installing from the command
I can't see what I'm doing wrong....
1an3
Post by 1an3 » 14 May 2021 14:51
I must've done something stupid to my server, I rebuilt it , minimal install, allowed it to talk out to anywhere on any port and it works. My bad. :roll:
shreyansh24
Post by shreyansh24 » 13 Oct 2021 11:24
Was there a fix for this?
I've just gone to build a new eFa server by simply running the 'curl -sSL https://install.efa-project.org | bash' command however I'm getting the following:
+----[SHA256]-----+
I've made sure NetworkManager is enabled and that it has full access to the internet on all ports, however it seems to set the following in resolv.conf and removes current DNS config so it then can't talk out.
nameserver 127.0.0.1
nameserver ::1
Any help would be greatly appreciated. I had this previously all configured through puppet and this was failing so testing the default install script also seems to fail.
1an3
Post by 1an3 » 13 Oct 2021 13:34
No, I never got to the bottom of what was wrong with my first attempt. I think I'd broken it somehow by trying to be clever. I had done all sorts like install webmin before installing efa - in the end I scrapped it, went for a minimum install, let it get to anywhere on any port in my edge firewall and then everything was fine.
Good luck!
