The notification email to the recipient doesn't show the link to release an email. A similar issue existing in ESVA whereby this happened to me when MailScanner couldn't resolve the hostname variable since I had to redirect the portal to port 81 and added:81 at the end of $hostname. However, in the EFA neither the default link, nor a link with hardcoded URL (http://mx.xxx.com/cgi-bin...) shows up in the email. I assume the issue isn't with the $hostname variable, but with any of the other 3 ($datenumber, $id and $token). In fact I found an article on the web where a version of MailScanner used $to instead of $token, but there was no reference to the version or any other hint. I will try one by one to exclude the variables and see when the link does get displayed. But if any of you are familiar with the problem, please advice of the solution.
Thanks,
goppi
Recipient Spam Report
Re: Recipient Spam Report
What do your Signature rules look like?
/etc/MailScanner/rules/sig.html.rules
/etc/MailScanner/rules/sig.text.rules
Also, what does the following rules look like in /etc/MailScanner/MailScanner.conf?
Spam Actions =
High Spam Actions =
Non Spam Actions =
Spam Actions =
High Spam Actions =
Non Spam Actions =
sig.html.rules
To: *@domain.com /etc/MailScanner/reports/en/inline.sig.in.html
To: default /etc/MailScanner/reports/en/inline.sig.out.html
The text rules is exactly the same with the exception of .txt instead of .html in both lines.
Spam Actions = store notify
High Scoring Spam Actions = store
Thanks for your help!
goppi
sig.html.rules
goppi
Change your Spam Actions as follows (you can also use EFA-Configure Spam Settings section to configure this)
Spam Actions = store notify custom(spam)
thanks - I have made the changes and guess I just need to wait now for a spam email to test the result.
will be back,
goppi
will be back,
goppi
Be sure to reload MailScanner too.
sudo service MailScanner reloadRe: Recipient Spam Report
I've the same problems.
Note that:
1) efa 3.0.4
2) the incoming sig rules are not bounded on domain
3) Spam Actions = store notify custom(spam)
The {Spam not delivered} subjected mail is correctly sended but the line showing the link is not showed.
Could u help me ?
Note that:
1) efa 3.0.4
Could u help me ?
Nevermind .. find the clue.
I'm focused on Spam Actions while problem was on High Spam
btw rule should be (in mailscanner.conf):
Spam Actions = store custom(spam)
Ad NOT:
Otherwise you will receive notifications twice: one from notify (without link) and one from custom script (with link).
Ad NOT:
