eFa-4.0.4 - MailScanner version 5.4.1 / CustomAction.pm Global symbol "$year"
rgwald
Post by rgwald »
After a new installation I am facing errors in the maillog referring to mailscanner as information below.
[root@efa custom]# MailScanner --lint
Trying to setlogsock(unix)
Could not use Custom Function code /usr/share/MailScanner/perl/custom/CustomAction.pm, it could not be "require"d. Make sure the last line is "1;" and the module is correct with perl -wc (Error: Global symbol "$year" requires explicit package name at /usr/share/MailScanner/perl/custom/CustomAction.pm line 154.
Global symbol "$mon" requires explicit package name at /usr/share/MailScanner/perl/custom/CustomAction.pm line 154.
Global symbol "$mday" requires explicit package name at /usr/share/MailScanner/perl/custom/CustomAction.pm line 154.
Global symbol "$hour" requires explicit package name at /usr/share/MailScanner/perl/custom/CustomAction.pm line 154.
Global symbol "$min" requires explicit package name at /usr/share/MailScanner/perl/custom/CustomAction.pm line 154.
Global symbol "$sec" requires explicit package name at /usr/share/MailScanner/perl/custom/CustomAction.pm line 154.
Compilation failed in require at /usr/share/MailScanner/perl/MailScanner/Config.pm line 752.
) at /usr/share/MailScanner/perl/MailScanner/Config.pm line 754.
CustomAction.pm
# Version 20210130
# # Function to create a pseudorandom 32 char token
sub randomtoken {
my $message = @_;
my ($token, $sha1);
$sha1 = Digest::SHA->new(1);
my ($timestamp) = sprintf("%d-%02d-%02d %02d:%02d:%02d", $year + 1900, $mon + 1, $mday, $hour, $min, $sec);
$sha1->add($message->{id}, $timestamp, $message->{size}, $message->{headers});
$token = $sha1->hexdigest;
return $token;
Other cases reported in other forums
https://github.com/E-F-A/v4/issues/281
https://github.com/E-F-A/v4/issues/282
Re: eFa-4.0.4 - MailScanner version 5.4.1 / CustomAction.pm Global symbol "$year"
4.0.4-5 yanked from repos and 4.0.4-6 going out with fix.
In the meantime...
sudo rm -f /usr/share/MailScanner/perl/custom/CustomAction.pm
sudo systemctl restart mailscanner
rgwald
Post by rgwald »
Mailscanner started without errors
Does this file interfere with some MailScanner operation functionality?
It does not. If MailScanner is starting okay you are fine and this will resolve itself in the next update.
rgwald
Post by rgwald »
Thank you very much.
It's OK.
