auto create Plesk email users in eFa
Posted: 02 Feb 2021 04:23
by angelo
I'm looking into creating accounts in EfA for all mailusers in Plesk (5000+).
Is there an easy command line to add users in MailScanner/Mailwatch/eFa ? Or does anybody has some experience with that?
Thank you,
Angelo
Re: auto create Plesk email users in eFa
Posted: 02 Feb 2021 16:58
This can be done and has been done. That's my short answer.
I'll post a longer answer this evening after work. I think there are a couple scripts lingering out there that could help.
Posted: 02 Feb 2021 17:04
by angelo
Ok, thanks. That would be great :D
Posted: 12 Feb 2021 03:46
by angelo
@shawniverson, did you have time to look into this more?
Thank you,
Angelo
Posted: 12 Feb 2021 20:02
Oh man I dropped the ball let me look around.
Posted: 12 Feb 2021 21:57
Do you have a way to export the users from Plesk?
Posted: 18 Feb 2021 21:28
by angelo
Yes, I do.
I can make an easy list of all the email addresses
thanks
Posted: 18 Feb 2021 21:30
by angelo
For those who want to know (from Plesk 17.x and up) :
/usr/local/psa/admin/sbin/mail_auth_view | awk '{print $2}'
