I'm having trouble releasing quarantined messages.
I always get the message in the mail log that the domain cannot be found.
Here is no-reply@wrongsubdomain.domain.tld.
I've looked everywhere for wrongsubdomain.domain.tld but can't find an entry.
Mail.domain.tld must be here ..
Details vom /var/log/maillog
Jan 21 12:01:40 Mail postfix/smtpd[14060]: connect from localhost[127.0.0.1]
Jan 21 12:01:40 Mail postfix/smtpd[14060]: NOQUEUE: reject: RCPT from localhost[127.0.0.1]: 450 4.1.8 <no-reply@wrongsubdomain.domain.tld>: Sender address rejected: Domain not found; from=<no-reply@wrongsubdomain.domain.$
Jan 21 12:01:40 Mail postfix/smtpd[14060]: disconnect from localhost[127.0.0.1] ehlo=1 mail=1 rcpt=0/1 rset=1 quit=1 commands=4/5
Many Thanks!
Problems with releasing Spam-Mails
Re: Problems with releasing Spam-Mails
Take a look in /var/www/html/mailscanner/conf.php
Thanks for the tip.
Unfortunately, I am not a Linux specialist and sometimes find it difficult.
Sometimes I think it might be easier to learn the topics piece by piece instead of using such extensive packages as EFA.
Thank you for your commitment!
