Ipv6 disabled but detected
Posted: 10 Jan 2021 16:26
just fresh installed and Efa.
First i thought lets at least enable IPV6 DNS but my VM doesnt get an IPv6 adress.
So i disabled it . See eFA configure output as shown below.
But i still get the following error message on the main login page:
MailWatch for MailScanner v1.2.15 running on eFa-4.0.3 ...ERROR INITIALIZATING IPV6, CHECK INTERNET ACCESS... - © 2006-2021
e) Return to main menu
--- Welcome to the eFa Configuration program ---
--- https://www.efa-project.org ---
Current and Proposed IP settings for eth0 are:
SETTING : CURRENT : PROPOSED
1) BOOTPROTO : none : none
2) IPV6_AUTOCONF : yes : yes
3) IP : 93.ccc.66.83 93.ccc.66.83
4) Netmask : 255.255.252.0 : 255.255.252.0
5) Gateway : 93.ccc.64.1 : 93.ccc.64.1
6) Use IPv6 DNS : no : no
7) IPv6 IP : :
8) IPv6 Prefix : :
9) IPv6 Gateway : :
10) DNS Recursion : ENABLED : ENABLED
11) Primary DNS : :
12) Secondary DNS : :
13) Hostname : efa4 : efa4
14) Domain Name : xxx.de : xxx.de
y) Make changes
c) Cancel
