/etc/cron.hourly/mailscanner:
/usr/sbin/ms-check: line 40: hostname: command not found
***SOLVED*** Recent Cron Error
I haven't had a chance to look into this yet but it doesn't appear to be effecting anything at the moment.
Re: Recent Cron Error
What do you get when you just enter
Should return your Fqdn hostname
manual start of /etc/cron.hourly/mailscanner returns no errors with me
hostnameShould return your Fqdn hostname
Just got a chance to look at this, and it appears the hostname package was missing. strange.
