Check RBL on second ip address in message header
victorburgos
Post by victorburgos »
Hi, I have some messages that are not being filtered with RBL on the second ip in message header-
  • I have spam lists enabled:
mailscanner spam lists.png (7.32 KiB) Viewed 5126 times
Many spam messages are not being filtered because the last ip on the header is not on any RBL.
However, if I check the second IP address, this one is listed on spamhaus, see next image:
mailscanner 2 ips on message header.png (40.31 KiB) Viewed 5126 times
In the end, the message arrives to the user even when 1 ip on the headers is listed on spamhaus:
x spam status no.png (49.16 KiB) Viewed 5126 times
I would like to know if mailscanner checks all ip addresses on the message header for RBLs or just the last ip.
If only the last ip address is checked, how can I enable checks on second and third ips on headers?
Thanks in advance for your help.
Re: Check RBL on second ip address in message header
in MailScanner.conf
If you do have another MTA between "the net" and your MS box, then you
really do need set this to 2.
Read IP Address From Received Header = 2
P.S.
When using fetchmail, the first IP is always 127.0.0.1
Use the --invisible option to deal with that
The big question: What if you have muliple IP's, or just one in .....
2021-01-04 22_05_54-MailWatc2.png (6.43 KiB) Viewed 5120 times
victorburgos
Thank you Henk, this would have taken me hours to figure out. :clap:
henk wrote: 04 Jan 2021 21:07 in MailScanner.conf
huh. I didn't know that one, and I needed it. Thanks!
