				Search Quarantine for messages "to"
				Posted: 30 Jan 2014 02:42
				by rickb813
				I need a little hint or help learn how to quickly search the QUARANTINE for all messages "To" a certain address within the daily batch - is there a combination to type in the "Jump to message" box to do this?
RB
				Re: Search Quarantine for messages "to"
				Posted: 30 Jan 2014 04:15
				Head over to Reports
Enter the date and click Add under Add Filter
Then...
Change to To: in the dropdown box, enter the To: address, and click Add.
Click Message Listing
That's it!
				Posted: 30 Jan 2014 12:39
				by rickb813
				Awesome Shawn!
Stay warm today -
RB
				Posted: 30 Jan 2014 14:14
				by johns961
				That works very well. It displays all the bad mail for someone that was not delivered.
But, what if someone claims they did not receive their email from uncle ed. Is there a way to display mail
that was delivered to a specific person ?
John!
				Posted: 30 Jan 2014 15:13
				by darky83
				It should also list all mail send to that user.
Only if you have configured the system to disable non spam only then you will see 'spam only'.
This is an option in EFA-Configure, the default value is to store all mail, but you can manually change this in EFA-Configure.
Regards,
d.
				Posted: 30 Jan 2014 21:53
				by rickb813
				OK, this question is a logical next one - if "non-spam" storage is turned on, is there already a chron setup to automatically delete mail that was stored to prevent filling the partition that was pre-selected for storage?
if there IS one setup, how long will the server default to storing email?
				Posted: 30 Jan 2014 22:28
				There is a cron.../etc/cron.daily/clean.quarantine
Default is 30 days (we may make it longer).
You will notice that it is disabled.  We identified this as an issue with the 3.0.0.0 release and will be fixing in 3.0.0.1 update, but you can enable yourself if you like.
				Posted: 31 Jan 2014 01:05
				by rickb813
				Done!
Enabled it Shawn - staying warm there?
				Posted: 31 Jan 2014 01:16
				Kkkkkkkind'vvvve.....
