GeoIP and Malwarepatrol Logs?
Posted: 14 Dec 2020 18:35
by Knorkator
unfortunately I have to ask another beginner question.
Where can I enter a GeoLite2 Key?
Unfortunately I can't find an entry in the menu and I can't find anything in the file system.
I have also created a free MalwarePatrol account and would like to know if this now works in EFA.
Somehow I am missing the file paths.
In /var/log/messages I have a line where Malwarepatrol appears... but I can't do anything with it.
maillog:Dec 14 19:19:16 efa opendmarc[1885]: 4*********9: malwarepatrol.net none
Translated with www.DeepL.com/Translator (free version)
Re: GeoIP and Malwarepatrol Logs?
Posted: 14 Dec 2020 20:55
viewtopic.php?&t=4068
Search the forum :idea:
Posted: 15 Dec 2020 09:04
by Knorkator
Hello Henk,
I have already searched for it in the forum.
Apparently not thorough enough... unfortunately there are always a lot of entries and sometimes you can't find the crucial one.
Especially not when this is to be found in the menu after all....
Sorry for that.
I have now entered the GeoLite2 key and started the update via the website.
Thanks a lot!
