Mailscanner 5.3.4 bug
Customer using a Groupwise mail server does not get addresses parsed correctly. Consequently mailscanner rejects message as malformed.
Example: joe@mail.com comes in as groupwise-joe@mail.com:1:1 , and thus gets tagged and whacked, returns an undeliverable to sender.
After downgrading to 5.3.3-1 and a permission repair mail is now flowing again.
------------ header from returned mail------------------
Reporting-MTA: dns; efa.mail.com
X-Postfix-Queue-ID: 4CQgFk47nZzBNBs2
X-Postfix-Sender: rfc822; joe@mail.com
Arrival-Date: Tue, 3 Nov 2020 11:43:54 -0800 (PST)
Final-Recipient: rfc822; groupwise-Joe@mail.com:1:1
Original-Recipient: rfc822;groupwise-Joe@mail.com:1:1
Action: failed
Status: 5.1.3
Diagnostic-Code: X-Postfix; bad address syntax
--=Part655B9640.0__Content-Type: message/rfc822
thank you EFA. Great app!!
Action: failed
Status: 5.1.3
Re: Mailscanner 5.3.4 bug
we have experienced the same problem and thanks to you we have reverted to the previous version and it's working now.
This is the output from our automatic update:
/etc/cron.daily/0yum-daily.cron:
warning: /etc/MailScanner/MailScanner.conf created as /etc/MailScanner/MailScanner.conf.rpmnew
Added new: Web Bug Replacement = https://s3.amazonaws.com/msv5/images/spacer.gif
Added new: Lockfile Dir = /var/spool/MailScanner/incoming/Locks
Added new: include /etc/MailScanner/conf.d/*
Summary
Read 386 settings from old /etc/MailScanner/MailScanner.conf.original
Used 384 settings from old /etc/MailScanner/MailScanner.conf.original
Used 4 default settings from new /etc/MailScanner/MailScanner.conf.dist
warning: /var/lib/unbound/root.key saved as /var/lib/unbound/root.key.rpmsave
warning: /etc/unbound/unbound.conf created as /etc/unbound/unbound.conf.rpmnew
Preparing to update eFa...
checkmodule: loading policy configuration from /var/eFa/lib/selinux/eFa.te
checkmodule: policy configuration loaded
checkmodule: writing binary representation (version 19) to /var/eFa/lib/selinux/eFa.mod
Update completed successfully!
The following updates will be applied on fap-mta01.emfa.pt:
Package Arch Version Repository Size
Updating:
MailScanner noarch 5.3.4-1.eFa.el7 eFa4 597 k
eFa noarch 1:4.0.3-12.eFa.el7 eFa4 104 k
unbound x86_64 1.11.0-1.eFa.el7 eFa4 927 k
unbound-libs x86_64 1.11.0-1.eFa.el7 eFa4 528 k
Installing for dependencies:
libtirpc x86_64 0.2.4-0.16.el7 base 89 k
python3 x86_64 3.6.8-13.el7 base 69 k
python3-libs x86_64 3.6.8-13.el7 base 7.0 M
python3-pip noarch 9.0.3-7.el7_7 updates 1.8 M
python3-setuptools noarch 39.2.0-10.el7 base 629 k
Transaction Summary
Install ( 5 Dependent packages)
Upgrade 4 Packages
The updates were successfully applied
This is what i see in the message listing, the system is adding that "groupwise-<emailaddress>:1:1 to every email.
04/11/20 11:22:51 vhmatos@emfa.pt groupwise-vitormatos02@gmail.com:1:1
Summary
Updating:
Transaction Summary
Upgrade 4 Packages
This isn't really a bug but appears to be a violation of RFC on part of Groupwise.
Doing some research. MailScanner is going to need to workaround the violation.
https://info-ims.arnold.narkive.com/GtK ... -extension
https://tools.ietf.org/html/rfc1891
https://tools.ietf.org/html/rfc3461
Yanked from production until we can get this fixed.
Anyone affected...
sudo yum downgrade MailScanner
sudo chown postfix:mtagroup /var/spool/MailScanner/milterin
sudo chown postfix:mtagroup /var/spool/MailScanner/milterout
Just wanted to report the same.
My investigation shows that after receiving mail from Groupwise (if Groupwise has DSN enabled) Mailscanner after scanning tries to pass mail to address found in ORCPT instead in TO.
I temporarily solved issue (have EFA in front of GW) with disabling DSN on Groupwise.
However, If we will get mail from outside Groupwise that has DSN enabled, it will be denied as undeliverable to groupwise-name.surname@mail.com:1:1
I am reporting issue to Microfocus, but anyway if EFA solves it (too) I would appreciate it.
goldengate
Concerned and interested in what others are seeing. We are running MailScanner 5.3.4 on Postfix as our outer filter and GroupWise 18.2.1 with DSN enabled on GWIA on the inside. GWIA is configured to relay through MailScanner. Checking our Postfix/MailScanner logs, I am not seeing the errors others are. If I filter the log on DSN, I see 62 entries in today's log both inbound and outbound to and from GWIA to MailScanner with the correct email address, no "groupwise-" appended and when I look at the properties of the email I sent today, it says "Transferred" as usual. Both our MailScanner and GW environments are upgrades from old origins though, so there may be things in the config files I have forgotten.
same here
We are using MailScanner in front of Exchange and getting this problem when partners send with Groupwise.
Downgrade MailScanner to 5.3.3 is a workaround.
Do you have DSN enabled on groupwise ?goldengate wrote: 12 Nov 2020 02:16 Concerned and interested in what others are seeing. We are running MailScanner 5.3.4 on Postfix as our outer filter and GroupWise 18.2.1 with DSN enabled on GWIA on the inside. GWIA is configured to relay through MailScanner. Checking our Postfix/MailScanner logs, I am not seeing the errors others are. If I filter the log on DSN, I see 62 entries in today's log both inbound and outbound to and from GWIA to MailScanner with the correct email address, no "groupwise-" appended and when I look at the properties of the email I sent today, it says "Transferred" as usual. Both our MailScanner and GW environments are upgrades from old origins though, so there may be things in the config files I have forgotten.
If you do not, then mail goes as normal. If you do, then you will have problem. So you will have it if someone will send you mail form DSN enabled Groupwise ...
Please update to resolve this issue. I have released 4.0.3-13 to resolve this and other related issues.
viewtopic.php?f=8&p=16901
goldengate
Yes as my description indicated, we have DSN enabled and are not seeing this problem.BSajovic wrote: 13 Nov 2020 09:39Do you have DSN enabled on groupwise ?goldengate wrote: 12 Nov 2020 02:16 Concerned and interested in what others are seeing. We are running MailScanner 5.3.4 on Postfix as our outer filter and GroupWise 18.2.1 with DSN enabled on GWIA on the inside. GWIA is configured to relay through MailScanner. Checking our Postfix/MailScanner logs, I am not seeing the errors others are. If I filter the log on DSN, I see 62 entries in today's log both inbound and outbound to and from GWIA to MailScanner with the correct email address, no "groupwise-" appended and when I look at the properties of the email I sent today, it says "Transferred" as usual. Both our MailScanner and GW environments are upgrades from old origins though, so there may be things in the config files I have forgotten.
GG
