CLAMAV SSL Download Error - UK Only SSL Cert Expired
Posted: 30 Oct 2020 11:42
by sharktech
ERROR: Download failed (35) ERROR: Message: SSL connect error
ERROR: getpatch: Can't download daily-25959.cdiff from
https://database.clamav.net/daily-25959.cdiff
ERROR: getcvd: Can't download daily.cvd from
https://database.clamav.net/daily.cvd
ERROR: Update failed for database: daily
ERROR: Database update process failed: Connection failed (5)
ERROR: Update failed.
Originally posted in V3 as i forgot i upgraded
Morning (UK) getting the above in an email constantly, i can download the files manually without issue. can i upload them and update manually?
Re: CLAMAV SSL Download Error
Posted: 30 Oct 2020 16:14
When you say you can download them manually, do you mean on the eFa itself?
Posted: 03 Dec 2020 15:34
by sharktech
Hi Shawn
No via a web browser from the same external IP. desperate to get this sorted
Posted: 03 Dec 2020 22:14
Please try this on the eFa and capture the error output
curl https://database.clamav.net/daily.cvd > daily.cvd
Posted: 07 Dec 2020 10:35
by sharktech
> curl
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
curl: (35) TCP connection reset by peer
i tried a wget aswell and got the below
> wget
--2020-12-07 10:35:17--
Resolving database.clamav.net (database.clamav.net)... 104.16.219.84, 104.16.218.84, 2606:4700::6810:db54, ...
Connecting to database.clamav.net (database.clamav.net)|104.16.219.84|:443... connected.
Unable to establish SSL connection
Posted: 07 Dec 2020 11:17
Try the following and gather the output:
openssl s_client -connect database.clamav.net:443
openssl s_client -connect database.clamav.net:443 -servername clamav.net -showcerts | openssl x509 -text -noout
Posted: 07 Dec 2020 11:23
by sharktech
i can see expiry errors.
CONNECTED(00000003)
depth=2 C = GB, ST = Greater Manchester, L = Salford, O = COMODO CA Limited, CN = COMODO ECC Certification Authority
verify return:1
depth=1 C = GB, ST = Greater Manchester, L = Salford, O = COMODO CA Limited, CN = COMODO ECC Domain Validation Secure Server CA 2
verify return:1
depth=0 CN = ssl392509.cloudflaressl.com
verify error:num=10:certificate has expired
notAfter=Oct 13 23:59:59 2020 GMT
verify return:1
verify return:1
Certificate chain
0 s:/CN=ssl392509.cloudflaressl.com
i:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO ECC Domain Validation Secure Server CA 2
1 s:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO ECC Domain Validation Secure Server CA 2
i:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO ECC Certification Authority
2 s:/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO ECC Certification Authority
i:/C=SE/O=AddTrust AB/OU=AddTrust External TTP Network/CN=AddTrust External CA Root
Server certificate
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
subject=/CN=ssl392509.cloudflaressl.com
issuer=/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=COMODO ECC Domain Validation Secure Server CA 2
No client certificate CA names sent
Peer signing digest: SHA256
Server Temp Key: ECDH, P-256, 256 bits
SSL handshake has read 3584 bytes and written 415 bytes
New, TLSv1/SSLv3, Cipher is ECDHE-ECDSA-AES128-GCM-SHA256
Server public key is 256 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-ECDSA-AES128-GCM-SHA256
Session-ID: A82D02788B2974CA264718DB1298F7A4A0A1CB1CEB0E9A164FF730D5E2C90855
Session-ID-ctx:
Master-Key: D9A9167B5971F43634C3B819DB5B6C60B3CB7CDB65C2C5B0631F120B4615572C044E499181B26D77316BB240B9C3D78A
Key-Arg : None
Krb5 Principal: None
PSK identity: None
PSK identity hint: None
TLS session ticket lifetime hint: 64800 (seconds)
TLS session ticket:
0000 - dd 32 37 29 01 e5 df d4-c1 87 d7 77 f5 5e 5e b0 .27).......w.^^.
0010 - c8 dd ea 4d 42 03 37 d7-92 d9 34 fa 21 8e ab 03 ...MB.7...4.!...
0020 - 02 c5 25 f6 44 6a 03 7f-77 24 5d cf 11 86 0e df ..%.Dj..w$].....
0030 - d5 c5 a8 27 33 b1 23 d4-6f 33 71 5e bc 76 72 97 ...'3.#.o3q^.vr.
0040 - 54 6d 89 de 92 e0 9f 4b-79 d0 e1 f9 f1 dd 79 cc Tm.....Ky.....y.
0050 - e8 6f d1 13 50 70 2c 00-fa 6f ad 56 60 58 74 5e .o..Pp,..o.V`Xt^
0060 - 31 66 47 0b 5a 50 b4 af-ab 98 d2 4e 76 af 3b 2f 1fG.ZP.....Nv.;/
0070 - 8e 7e ee db cf c2 c5 fa-8f 1c 08 c4 d1 73 18 1c .~...........s..
0080 - 91 02 eb f3 53 e0 38 1d-5f 9e 4b 36 7d c9 6e de ....S.8._.K6}.n.
0090 - 6b db a9 76 2c 73 07 4e-a1 1e ce a8 3c cd 8e 7f k..v,s.N....<...
00a0 - c4 09 b9 12 f1 48 ae 1c-99 b7 e0 21 7d 44 13 6f .....H.....!}D.o
Start Time: 1607340042
Timeout : 300 (sec)
Verify return code: 10 (certificate has expired)
closed
verify return:1
verify return:1
verify return:1
verify return:1
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
e7:28:4e:d7:e1:29:eb:04:df:95:78:6a:e4:cd:8a:d0
Signature Algorithm: ecdsa-with-SHA256
Issuer: C=GB, ST=Greater Manchester, L=Salford, O=COMODO CA Limited, CN=COMODO ECC Domain Validation Secure Server CA 2
Validity
Not Before: Apr 6 00:00:00 2020 GMT
Not After : Oct 13 23:59:59 2020 GMT
Subject: CN=ssl392509.cloudflaressl.com
Subject Public Key Info:
Public Key Algorithm: id-ecPublicKey
Public-Key: (256 bit)
pub:
04:0c:b2:3d:e1:a0:35:46:7b:0c:30:95:c6:62:17:
5d:b1:a0:04:71:27:f5:d7:30:4b:fa:fa:db:ec:5f:
20:c3:58:dc:12:cc:b2:62:31:f1:1e:5e:99:8f:dd:
43:f4:f9:1a:45:17:e3:a8:88:31:30:bd:f1:be:87:
bc:5a:d6:f0:f2
ASN1 OID: prime256v1
NIST CURVE: P-256
X509v3 extensions:
X509v3 Authority Key Identifier:
keyid:40:09:61:67:F0:BC:83:71:4F:DE:12:08:2C:6F:D4:D4:2B:76:3D:96
X509v3 Subject Key Identifier:
0E:85:B3:45:D0:81:69:D0:98:5D:65:83:49:60:2C:70:4B:49:77:72
X509v3 Key Usage: critical
Digital Signature
X509v3 Basic Constraints: critical
CA:FALSE
X509v3 Extended Key Usage:
TLS Web Server Authentication, TLS Web Client Authentication
X509v3 Certificate Policies:
Policy: 1.3.6.1.4.1.6449.1.2.2.7
CPS: https://sectigo.com/CPS
Policy: 2.23.140.1.2.1
X509v3 CRL Distribution Points:
Full Name:
URI:http://crl.comodoca4.com/COMODOECCDomainValidationSecureServerCA2.crl
Authority Information Access:
CA Issuers - URI:http://crt.comodoca4.com/COMODOECCDomainValidationSecureServerCA2.crt
OCSP - URI:http://ocsp.comodoca4.com
CT Precertificate SCTs:
Signed Certificate Timestamp:
Version : v1(0)
Log ID : 07:B7:5C:1B:E5:7D:68:FF:F1:B0:C6:1D:23:15:C7:BA:
E6:57:7C:57:94:B7:6A:EE:BC:61:3A:1A:69:D3:A2:1C
Timestamp : Apr 6 18:51:58.024 2020 GMT
Extensions: none
Signature : ecdsa-with-SHA256
30:46:02:21:00:EC:CA:4F:2C:0B:94:72:58:6C:BC:20:
45:72:5C:6E:7D:D1:6F:7C:DF:E0:27:6A:75:E9:0B:54:
C6:67:B1:0E:12:02:21:00:B2:70:4E:50:7A:F9:49:CA:
97:40:21:4B:22:17:B8:F2:EC:58:62:E7:28:7B:AA:E2:
E9:B3:68:A1:20:F7:05:56
Version : v1(0)
Log ID : E7:12:F2:B0:37:7E:1A:62:FB:8E:C9:0C:61:84:F1:EA:
7B:37:CB:56:1D:11:26:5B:F3:E0:F3:4B:F2:41:54:6E
Timestamp : Apr 6 18:51:58.072 2020 GMT
Extensions: none
30:46:02:21:00:9B:53:00:3B:C3:7F:21:7E:F7:88:6C:
63:FD:B3:63:3A:57:CD:E7:34:37:74:6A:67:B1:6A:D9:
E3:58:4A:0A:9F:02:21:00:DC:0C:DB:30:27:5D:D9:A3:
CE:EB:A2:44:69:26:66:48:5A:5D:F9:8D:C8:84:EC:0B:
E1:37:F9:3D:78:C3:16:2D
X509v3 Subject Alternative Name:
DNS:ssl392509.cloudflaressl.com
30:45:02:20:70:19:15:5f:c3:a1:ba:50:36:73:d8:40:1d:4b:
e1:90:99:54:8d:18:d5:17:64:46:93:1d:d9:92:b3:3d:18:1f:
02:21:00:ee:69:3b:08:e6:b5:5a:31:0b:b5:25:5d:3c:65:63:
d3:7f:6d:44:24:28:ac:e8:bf:87:02:67:13:29:93:ed:e6
Posted: 07 Dec 2020 11:38
That is very strange, the cert is expired at ssl392509.cloudflaressl.com from your location. You may need to reach out to clamav and have them fix that certificate in your region.
by sharktech
Yep, that was the first thing i checked. Can I manually update it?
Posted: 07 Dec 2020 11:45
I'm not sure if it will help but you can try to update your ca-certificate store
Posted: 07 Dec 2020 11:49
by sharktech
no updates available
I've contacted thm, just waiting back now
Thanks for the help
Re: CLAMAV SSL Download Error - UK Only SSL Cert Expired
Posted: 07 Dec 2020 13:44
by sharktech
Shawn
just tried those commands on another linux box and they connected to a different server and got a valid response
CONNECTED(00000005)
depth=2 C = IE, O = Baltimore, OU = CyberTrust, CN = Baltimore CyberTrust Root
verify return:1
depth=1 C = US, O = "Cloudflare, Inc.", CN = Cloudflare Inc ECC CA-3
verify return:1
depth=0 C = US, ST = CA, L = San Francisco, O = "Cloudflare, Inc.", CN = sni.cloudflaressl.com
verify return:1
Certificate chain
0 s:C = US, ST = CA, L = San Francisco, O = "Cloudflare, Inc.", CN = sni.cloudflaressl.com
i:C = US, O = "Cloudflare, Inc.", CN = Cloudflare Inc ECC CA-3
1 s:C = US, O = "Cloudflare, Inc.", CN = Cloudflare Inc ECC CA-3
i:C = IE, O = Baltimore, OU = CyberTrust, CN = Baltimore CyberTrust Root
Server certificate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subject=C = US, ST = CA, L = San Francisco, O = "Cloudflare, Inc.", CN = sni.cloudflaressl.com
issuer=C = US, O = "Cloudflare, Inc.", CN = Cloudflare Inc ECC CA-3
Peer signature type: ECDSA
Server Temp Key: X25519, 253 bits
SSL handshake has read 2507 bytes and written 401 bytes
Verification: OK
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
Post-Handshake New Session Ticket arrived:
SSL-Session:
Protocol : TLSv1.3
Cipher : TLS_AES_256_GCM_SHA384
Session-ID: BD4F01B0B6316EC3AA66749B7870CF52BF9EB323F6364E04E5713E22760D0C90
Session-ID-ctx:
Resumption PSK: 3D1113CCDDEDE5B991C4E8641521BE9BF7B41F25C0EF8F9EE6CFA8B28D1BB1CF96E4B6DD4D4F715BE5F8586051FD9127
PSK identity: None
SRP username: None
TLS session ticket:
0000 - c7 f7 d6 69 df 50 48 09-44 4a 11 b5 22 38 26 ca ...i.PH.DJ.."8&.
0010 - df 3f c6 b7 71 d0 4d bd-72 f9 43 3b 70 36 e2 6c .?..q.M.r.C;p6.l
0020 - 37 8f d8 d7 fb 58 ff df-b9 7c d9 9d 65 f9 38 90 7....X...|..e.8.
0030 - 02 a6 9a ab b3 20 27 3d-88 61 77 71 d3 af 8b 6e ..... '=.awq...n
0040 - f6 bf 9b c6 86 60 1e f1-5e d1 ce 59 d2 0a 9a 2e .....`..^..Y....
0050 - 97 59 cd e9 1e f4 7e 5a-eb 44 f9 4f 9b 6d 03 fb .Y....~Z.D.O.m..
0060 - d4 09 d0 c3 5d 0b 4d 43-af cb 3c 6d 07 6d 5a 0a ....].MC..<m.mZ.
0070 - 4a d9 b8 bb 1d 3f f3 bf-3b 0c 1a 44 45 bc 06 c1 J....?..;..DE...
0080 - c4 84 cb f6 1a 24 a4 80-fc f6 3f 28 2b 1a 53 af .....$....?(+.S.
0090 - 53 b2 a7 60 99 c1 d7 e6-c9 9d ec 75 e2 d3 bc 4b S..`.......u...K
00a0 - c3 21 d2 16 fa a6 7c 3c-50 c7 70 3b 5f 0f 5a 52 .!....|<P.p;_.ZR
00b0 - 9b da 5d 42 e8 d3 05 84-75 f3 4b a8 f2 a1 42 e5 ..]B....u.K...B.
Start Time: 1607348590
Timeout : 7200 (sec)
Extended master secret: no
Max Early Data: 0
read R BLOCK
SSL-Session:
Protocol : TLSv1.3
Session-ID: 360F77A325177BCCB9EF57C47067BA4B037941794956EFFF4614D0D98339C442
Session-ID-ctx:
Resumption PSK: FA3180386A2E57524109ACAFA920222FD5A94664F3542D33648C4629C9905CC92996507CACF6C0A349823B601B3A3C25
PSK identity: None
SRP username: None
TLS session ticket:
0010 - 28 86 81 0e bb a9 66 b0-c1 36 14 9a 0d 63 31 fb (.....f..6...c1.
0020 - e1 ac b1 ba 10 10 b4 60-81 a5 61 98 f4 ed 90 29 .......`..a....)
0030 - 23 29 5a b1 dd 8a d4 d5-57 2c 95 6d 48 50 f5 6c #)Z.....W,.mHP.l
0040 - e2 e2 d2 31 6a 5f 62 2f-bd 07 bb 68 bf 48 52 be ...1j_b/...h.HR.
0050 - 1c 50 0c 44 d3 6b 07 ae-59 b9 08 29 77 8e 64 57 .P.D.k..Y..)w.dW
0060 - 7f cc ac 82 47 36 f8 1e-bc 44 5b 64 47 e7 87 50 ....G6...D[dG..P
0070 - 95 28 fe ff 94 ec 01 2b-26 88 c1 6f b2 eb c2 cc .(.....+&..o....
0080 - 56 36 af 25 9c b4 07 23-52 4a 89 05 2a ba 9a e6 V6.%...#RJ..*...
0090 - f1 11 f6 37 c0 bf 7f 39-60 43 c3 c7 3b 65 da c6 ...7...9`C..;e..
00a0 - b7 8a 49 da 8b f0 8f 16-64 ac bb b7 1d df 91 2f ..I.....d....../
00b0 - 3c f9 69 46 90 ed 77 a6-5a 8c c9 15 22 3a 9c 72 <.iF..w.Z...":.r
Max Early Data: 0
read R BLOCK
closed
Posted: 09 Dec 2020 09:22
by sharktech
Hi Shawn
Did you look into more after my last reply?
TIA
Posted: 14 Dec 2020 11:43
I am wondering if there is a difference in the dns between the two servers you tested.
Posted: 28 Dec 2020 08:12
by sharktech
Hi Shawn
No difference at all, i'm spooling up a fresh install to test.
Posted: 20 Jan 2021 13:58
by sharktech
Hi Shawn
installed a fresh Centos8 server and still the same, just done a Centos7 install and it works lol
