Issues upgrading to eFA 4.0.3 on CentOS7
bms8197
Post by bms8197 »
I'm running the latest CentOS 7.x version. I've got an email notification that the eFa upgrade cron failed. The issue seems to be with fail2ban...
root@efa4 /root # yum update
Loaded plugins: fastestmirror
* base: mirrors.xservers.ro
* eFa4-Testing: dl.efa-project.org
* epel: mirrors.nav.ro
* extras: mirrors.ch-center.com
* updates: mirrors.ch-center.com
Resolving Dependencies
--> Running transaction check
---> Package dovecot.x86_64 1:2.2.36-6.el7 will be updated
---> Package dovecot.x86_64 1:2.2.36-6.el7_8.1 will be an update
---> Package eFa.noarch 1:4.0.2-31.eFa.el7 will be updated
---> Package eFa.noarch 1:4.0.3-6.eFa.el7 will be an update
--> Processing Dependency: fail2ban >= 0.11.1-9 for package: 1:eFa-4.0.3-6.eFa.el7.noarch
---> Package httpd24u.x86_64 0:2.4.43-1.el7.ius will be updated
---> Package httpd24u.x86_64 0:2.4.46-1.el7.ius will be an update
---> Package httpd24u-filesystem.noarch 0:2.4.43-1.el7.ius will be updated
---> Package httpd24u-filesystem.noarch 0:2.4.46-1.el7.ius will be an update
---> Package httpd24u-mod_ssl.x86_64 1:2.4.43-1.el7.ius will be updated
---> Package httpd24u-mod_ssl.x86_64 1:2.4.46-1.el7.ius will be an update
---> Package httpd24u-tools.x86_64 0:2.4.43-1.el7.ius will be updated
---> Package httpd24u-tools.x86_64 0:2.4.46-1.el7.ius will be an update
---> Package newrelic-infra.x86_64 0:1.12.4-1.el7 will be updated
---> Package newrelic-infra.x86_64 0:1.12.6-1.el7 will be an update
Error: Package: 1:eFa-4.0.3-6.eFa.el7.noarch (eFa4-Testing)
Requires: fail2ban >= 0.11.1-9
Any ideeas how to solve this?
bms8197
Re: Issues upgrading to eFA 4.0.3 on CentOS7
Post by bms8197 »
Sorry, my bad, I had fail2ban excluded in yum.conf. All good now...
