Just brought up my EFA 4 system to day and its sending out emails ok but when I went to check /var/log/maillog it was empty. I am used to postfix send ing logs to /var/log/maillog. Any idea why I'm not getting any email logs?
Nothing showing up in /var/log/maillog but EFA working
Re: Nothing showing up in /var/log/maillog but EFA working
Acting like syslog was not installed. Did a yum install syslog and it said it was installed, but when I tried to start it then it said service was not found.
[root@efa4 ~]# yum install syslog
Last metadata expiration check: 1:58:03 ago on Sun 04 Oct 2020 06:33:53 PM CDT.
Package systemd-239-31.el8_2.2.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
[root@efa4 ~]# service syslog restart
Redirecting to /bin/systemctl restart syslog.service
Failed to restart syslog.service: Unit syslog.service not found.
Nothing to do.
Complete!
Googled symptoms and found article about DNF command
https://linuxconfig.org/install-syslog-on-redhat-8
Working great now.
Working great now.
I had exactly the same issue, I am so used to looking at /var/log/maillog to see what is going on.
I followed the link you posted webguyz and now logging is enabled!
This was on a brand new CentOS 8 build.
