usually if double file extensions at attachments are made (.doc.pdf) eFa blocks them.
There is no possibility to manage this, ie to allow that or to send a warning message to receipient or sender. Such mails are "lost in space".
Feature Request: send a warning mail to both, sender and receipient which informs about the multiple file extension problem.
Funny if three extensions are made, the
a) eFa sends mail without complaint
b) Windows is totally confused...
(see attached pic "multipke file extensions.png")
multiple file extensions
- multiple file extensions.png (9.62 KiB) Viewed 6503 times
Re: multiple file extensions
Going to take a deeper look at this.
