Use multiple recipient delimiters
Mr. Happy
Post by Mr. Happy » 12 Sep 2020 15:27
Currently the + is working as a delimiter, but I would like to use bot + and -.
The reason is that not every company I want a different mailaddress for supports the +.
The issue is I can't get the +- or minus to work.
With only the + it works.
With the +- it only works for +.
With the - it fails.
In the maillog it prints
Recipient address rejected: undeliverable address: No user at this address
I did restart Postfix after each time I changed the delimiter and after that I sent a testmail.
What am I missing??
smyers119
Re: Use multiple recipient delimiters
Post by smyers119 » 12 Sep 2020 16:50
Why are you messing with the recipient delimiter at the spam gateway level? That sounds like a job for the Mail Server, the spam gateway should just be passing it on as it is.
Mr. Happy
Post by Mr. Happy » 12 Sep 2020 16:54
smyers119 wrote:
12 Sep 2020 16:50
'Cause I' m also using recipient filtering at efa....
smyers119
Post by smyers119 » 12 Sep 2020 16:58
Did you check what version postfix is running. It only supports multiple delimiters in 2.11 and later
Mr. Happy
Post by Mr. Happy » 12 Sep 2020 17:02
smyers119 wrote:
12 Sep 2020 16:58
According to
postconf mail_version
I have
mail_version = 3.4.8
smyers119
Post by smyers119 » 12 Sep 2020 17:07
If that is not the problem then post the log, maybe "propagate_unmatched_extensions" is messing you up? (if its even configured) (I don't have eFa in front of me to investigate myself)
Mr. Happy
Post by Mr. Happy » 12 Sep 2020 19:59
smyers119 wrote:
12 Sep 2020 17:07
I don't know what was the matter, but I rebooted the vm and now it works fine... :o
Thanks..
