DNS Recursion Issue
Posted: 09 Aug 2020 14:51
I am getting a problem after installing EFA v4 three times. At MailWatch no message at Recent Message/Quarantine wasn't shown. I try to dig out the problem with old post on this forum but in vain.
I read shawniverson post which says enable DNS Recursion. I try to do it but if I Disabled it then it will remain disable and vise versa. After the first fresh installation of EFA, I Disabled it and it will remain disabled. Then I try to Enabled it but the results are the same. After third attempt, I try again and got the same four liner error
On the third attempt, when changing DNS Recursion to Disable at the Configuration menu. It accepts my local DNS but afterward gives this four liner error. (Just to inform, this message come on every time).
sed: -e expression #1, char 38: unknown command: `.'
sed: -e expression #1, char 41: unknown command: `.'
sed: -e expression #1, char 47: unknown command: `.'
sed: -e expression #1, char 48: unknown command: `.'
All done
and last time also give
/var/eFa/lib/eFa-Configure/func_ipsettings: line 133: RECURSIVEDNS: command not found
Recursion will be DISABLED. Please set your DNS entries.
if I provide DNS the above mention four-line error occurred.
I struggle a lot by doing RND at this forum but with no success. So looking forward for your help.
All done
