Not using downloaded eFa4/repomd.xml because it is older than what we have
Posted: 02 Jul 2020 15:38
by cryptz
getting this the last few days, i tried "yum clean all" and it went away for a few hours but came right back today. I believe its an issue with the repo but a bit unsure.
Not using downloaded eFa4/repomd.xml because it is older than what we have:
Current : Wed Jul 1 18:02:05 2020
Downloaded: Sun Jun 28 18:02:08 2020
Re: Not using downloaded eFa4/repomd.xml because it is older than what we have
Posted: 22 Oct 2020 16:32
by b0mmer
Seeing the same message hourly from cron. Started October 20, 2020 at 10:12 AM Eastern time.
Wondering if you were able to resolve this last time, or if it just went away on its own?
/etc/cron.hourly/0yum-hourly.cron:
Current : Mon Oct 19 18:02:05 2020
Downloaded: Sun Oct 18 18:02:06 2020
Posted: 07 Jan 2021 23:00
by ouoertheo
I get this in batches pretty frequently too, probably every week or two, then they disappear til next time. I saw a reply on centos forums
https://forums.centos.org/viewtopic.php?t=63658 saying it was something at the repo end. Another search brought up a github conversation
https://github.com/sous-chefs/yum/issues/96 they are mentioning that its when a downstream repo is out of sync from an upstream repo. So perhaps we are seeing mirrors that are out of sync.
Might go to explain what's happening, but not quite sure what to do to mitigate it. For me, I'll probably just ignore them for now.
Posted: 08 Jan 2021 00:58
by remko
I get the same message every hour since today.
Doing some more digger I found the ssl certificate at
https://dl.efa-project.org/ expired today.
[root@efa-server]# yum check-update
Loaded plugins: fastestmirror
Determining fastest mirrors
Could not retrieve mirrorlist https://dl.efa-project.org/rpm/eFa4/mirrors-eFa error was
14: curl#60 - "Peer's Certificate has expired."
epel/x86_64/metalink | 32 kB 00:00:00
* base: mirrors.supportex.net
* epel: mirror.nl.leaseweb.net
* extras: mirror.hostnet.nl
* updates: mirrors.supportex.net
base | 3.6 kB 00:00:00
https://dl.efa-project.org/rpm/eFa4/x86_64/repodata/repomd.xml: [Errno 14] curl#60 - "Peer's Certificate has expired."
Trying other mirror.
It was impossible to connect to the CentOS servers.
This could mean a connectivity issue in your environment, such as the requirement to configure a proxy,
or a transparent proxy that tampers with TLS security, or an incorrect system clock.
You can try to solve this issue by using the instructions on https://wiki.centos.org/yum-errors
If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
One of the configured repositories failed (eFa-Project),
and yum doesn't have enough cached data to continue. At this point the only
safe thing yum can do is fail. There are a few ways to work "fix" this:
1. Contact the upstream for the repository and get them to fix the problem.
2. Reconfigure the baseurl/etc. for the repository, to point to a working
upstream. This is most often useful if you are using a newer
distribution release than is supported by the repository (and the
packages for the previous distribution release still work).
3. Run the command with the repository temporarily disabled
yum --disablerepo=eFa4 ...
4. Disable the repository permanently, so yum won't use it by default. Yum
will then just ignore the repository until you permanently enable it
again or use --enablerepo for temporary usage:
yum-config-manager --disable eFa4
or
subscription-manager repos --disable=eFa4
5. Configure the failing repository to be skipped, if it is unavailable.
Note that yum will try to contact the repo. when it runs most commands,
so will have to try and fail each time (and thus. yum will be be much
slower). If it is a very temporary problem though, this is often a nice
compromise:
yum-config-manager --save --setopt=eFa4.skip_if_unavailable=true
failure: repodata/repomd.xml from eFa4: [Errno 256] No more mirrors to try.
Posted: 08 Jan 2021 02:20
by remko
More in this thread and solved
viewtopic.php?f=5&t=4591
Posted: 05 Apr 2022 22:37
by Brionlax
Is anyone else seeing this message today?
I am located in Canada and I think that the mirror closest to me might be out of sync. Since I'm fairly new to using linux, is there any way that I can check/correct this error?
Cheers
Posted: 15 Feb 2023 18:38
by kikowss
This is still an issue for me I got those for the last 15 days.
Current : Sun Feb 12 01:02:07 2023
Downloaded: Mon Dec 26 01:02:06 2022
I have check and certificate of
https://dl.efa-project.org looks good:
echo '' | openssl s_client -servername dl.efa-project.org -connect dl.efa-project.org:443 2>/dev/null | openssl x509 -noout -dates
notBefore=Jan 15 13:05:44 2023 GMT
notAfter=Apr 15 13:05:43 2023 GMT
is there any way that I can fix that error ?
Posted: 16 Feb 2023 13:34
by sunnyg
Same here the error I have been getting since yesterday is:
Current : Tue Feb 14 18:02:07 2023
Downloaded: Sun Dec 25 18:02:06 2022
A quick update running the command
Seems to have resolved the issue
Posted: 16 Feb 2023 15:30
by sunnyg
kikowss wrote: 15 Feb 2023 18:38
Hi run the command : yum clean metadata
Posted: 16 Feb 2023 17:09
by kikowss
sunnyg wrote: 16 Feb 2023 15:30
Thank you sunnyg
Posted: 16 Nov 2023 07:27
by kikowss
Looks like
https://dl.efa-project.org/ certificate is expired on 11/15/2023
