i am getting this error daily:
/etc/cron.daily/0yum-daily.cron:
Failed to check for updates with the following error message:
Failed to build transaction: php72u-mbstring-7.2.31-2.el7.ius.x86_64 requires libonig.so.5()(64bit)
yum list shows:
Installed Packages
oniguruma.x86_64 5.9.5-3.el7 @epel
but the lib provided seems to be:
[root@dlp-upemx01 ~]# locate libonig
/usr/lib64/libonig.so.2
/usr/lib64/libonig.so.2.0.0
am i missing something, or am i not the only one getting this error?
getting anacron about missing lib
Re: getting anacron about missing lib
I saw this appear but it resolved itself for me. Try running a yum clean all and another yum update.
There's some massive maintenance going on on the Fedora (epel) repos's.
just take a look :https://status.fedoraproject.org/
and a nice nagios status map https://nagios-external.fedoraproject.o ... p?host=all
Had some issues updating, but the only thing you need is patience
