MailWatch works well with DBD::mysql version 4.042 or greater, which supports utf8mb4 charset used by MySQL;
yep0213
Post by yep0213 »
perl-DBD-MySQL-4.023-6.el7.x86_64 already installed and latest version
Is there any way to upgrade perl-DBD-MySQL above 4.0.42
Now log in to mailwatch web, check the mail log, and some of the mail headers will display garbled code
RE: 管理部 \xD5\x88提供\xC8A\x96|的\xBDM\xC2\x9A\xBDY\x98\x8B \xBEo急\x91\xAA\xD7\x83\xCC\x8E理程序2-040-03 (2) .doc
Re: MailWatch works well with DBD::mysql version 4.042 or greater, which supports utf8mb4 charset used by MySQL;
I've not seen this problem in quite a while.
Just checking my efa4 instance now, and I don't see the problem at all. See the following:
Screen Shot 2020-06-18 at 18.35.png (236.78 KiB) Viewed 3142 times
In fact, it appears even better than before where I would still get a couple of character encoded with \x
[edit] Actually, I just checked my efa3 instance and I've no more \x encoded subjects anymore. So, I guess it's been a couple of years since I've seen this problem.
What version of EFA are you running?
yep0213
Post by yep0213 »
I am currently installing the latest version of efa 4.0.2. The computer in my test environment is a traditional system. Sometimes the title of some simplified or traditional emails will be garbled
Wouldn't you know it. Just today, I had an email with the following subject show up just now
Re:第一时间获取到Buyer,ceo联系方\xE5\xBC\x8F,开发客户再也不是问题
The actual subject from the original message is:
Subject: =?utf-8?B?UmU656ys5LiA5pe26Ze06I635Y+W5YiwQnV5ZXLvvIxjZW/ogZTns7vmlrnl?=
 =?utf-8?B?vI/vvIzlvIDlj5HlrqLmiLflho3kuZ/kuI3mmK/pl67popg=?=
When released, outlook shows the subject as
Re:第一时间获取到Buyer,ceo联系方式,开发客户再也不是问题
So, it looks like it has trouble displaying (some?) simplified characters?
