				how to add domains etc?
				Posted: 24 Jan 2014 09:55
				by martinwa
				In ESVA adding domains is done with ESVA-domainadd but how is it done in EFA?
Great software by the way
Regards
Martin
				Re: how to add domains etc?
				Posted: 24 Jan 2014 10:00
				by darky83
				Still busy writing the howto (live somewhere today
in short:
Logon with ssh with the user you created during the setup
- EFA-Configure will automatically start up
- Go to option
8) Mail  Settings
- Go to option
4) Transport settings
Here you can add/remove/edit your domains.
				Posted: 24 Jan 2014 10:01
				Also,
Spam Settings --> Inline Signature Rules allow you to add domains to the MailScanner signature rules.
				Posted: 24 Jan 2014 10:38
				by martinwa
				In ESVA adding a domain also added a user with login rights to the web-interface.
This user could login and release mails from his domain only...
In time, will this be possible in EFA?
Regards
Martin
				Posted: 24 Jan 2014 10:52
				Hello Martin,
For now, simply create a new user in the domain as follows using MailWatch under Tools/Links
username: <myadmin>@<mydoman>
Name, password, etc.
Under User Type, choose "Domain Administrator"
				Posted: 24 Jan 2014 12:38
				by martinwa
				thank you - I try that.
Best regards
Martin
				Posted: 11 Feb 2014 09:25
				by b19wll
				Hello
I have added a user under mailwatch as above and can log in as that user and see all the email for the domain. I then started to whitelist some domains, then to double check I looked at the lists section only to find that the whitelist entries that I made earlier were not listed under the domain administrator login. However when I log in as admin and look at the lists, I can see the entries that I made for the domain administrator logon.
What do I need to do to see those entries when logged in as the domain administrator?
Will
				Posted: 11 Feb 2014 09:44
				Can you share an example entry?
Domain Administrators should only see entries for their own domains:
someperson@somewhere.net
To:
someperson@mydomain.com
				Posted: 11 Feb 2014 16:31
				by b19wll
				logged in as admin I can see;
To: recievingdomain.net
Whilst logged in as a domain administrator nothing is listed.
I know that the W/L is working as the emails are showing as green.
Will
				Posted: 11 Feb 2014 21:51
				Checking into this...
				Posted: 11 Feb 2014 22:40
				I believe we have a bug...
Just posted an issue to mailwatch
https://github.com/mailwatch/1.2.0/issues/52
Seeing if I can come up with a workaround or temporary fix...
				Posted: 11 Feb 2014 22:47
				by b19wll
				Posted: 11 Feb 2014 22:49
				Bug found!
MailWatch has a typo in /var/www/html/mailscanner/lists.php on line 156...
 $todomain1 = strtolower($url_domain);
This code should read...
 $todomain = strtolower($url_domain);
Unfortunately, this means that existing whitelist and blacklist entries are screwed up and will either have to be removed and readded or directly modified in the mailscanner whitelist and blacklist tables
				Posted: 11 Feb 2014 22:50
				by b19wll
				Wow that was fast, I'll change the chide note and report back
				Posted: 11 Feb 2014 23:07
				by b19wll
				Ok that works great now, but I think I may have stumbled on another bug
I went ahead and added several entries into the W/L both in the format
name@domain.com
to:
name@domain.net
and
to: domain.net
I can delete the entries that are in the format
name@domain.com, but not the ones that are listed as domain.com?
Will
PS forgot to mention that I can delete any entry while logged in as admin, the above only happens when I am logged in as a domain administator
				Posted: 12 Feb 2014 15:02
				I'll check into this too.
				Posted: 13 Feb 2014 21:57
				Posted: 13 Feb 2014 22:01
				by b19wll
				I'll edit the file and test, thanks for the info
Will
				Posted: 13 Feb 2014 23:12
				by b19wll
				Just changed the lists.php as shown on the github link and can now delete as a domain administrator.
Will add a standard user account tomorrow and see if that works.
Will
