First of all, thanks for all the great work! I've been using eFa for a number of years, both private and professional, and it's a really good solution for spam fighting. At the moment I'm flooded by email from tld .xyz, and .ml (Mali) domains. When I blacklist these tld's (without "*", "." or "@", they're not blocked. I have checked all the related subjects in the forum, and it seems there are several related to this issue. Does this need a RFC? What is the status of blocking top level domains?
Blacklist TLD
Re: Blacklist TLD
Needs to be in the format
*.gov
Re: Blacklist TLD
Thanks for the tip. I now get all this spam from .icu domains. I added a blacklist for *.icu and it works. Feel a bit silly now.
Thanks a lot!
Thanks a lot!
