How to check SaneSecurity signatures when scanning
peawet08
Post by peawet08 » 12 May 2020 14:24
I'm trying to check that the SaneSecurity signatures are being used when scanning emails.
I sent through an email with a sample signature that should have been detected but it got through. When I ran the clamav-unofficial-sigs.sh file, it had only run 10 minutes prior to me running it manually.
Are they in use by default?
Does anything have to be enabled for them to be used?
How can I add a header to the email highlighting the SaneSecurity category that was found?
P
smyers119
Re: How to check SaneSecurity signatures when scanning
Post by smyers119 » 12 May 2020 17:37
Just check the master.conf
