outgoing mail server (Client host rejected) error
TFNcap
Post by TFNcap »
Hello to everyone
I have been using efa as the incoming server for a while
I'm glad
my question is
can I use EFA as an outgoing mail server
example
1- domain name and ip also added to efa
2- relay made from main server
when I send an email
I'm getting an error
<tuxxxxxxap@gmail.com>: host 17x.20.2xx.x94[17x.20.2xx.x94] said: 554 5.7.1
    <s1.tuxxxxxst.com[17x.20.2xx.x95]>: Client host rejected: Access denied (in
    reply to RCPT TO command)
ip 17x.20.2xx.x94 EFA
ip 17x.20.2xx.x95 Sender Server (relay to efa)
I would be glad if you guide...
eFa-4.0.2 - ©
TFNcap
Re: outgoing mail server (Client host rejected) error
Post by TFNcap »
okay i am changing my question
Can I use EFA as an outgoing mail server ?
Are there any users who use it as mail server?
eFa-4.0.2 - ©
smyers119
Post by smyers119 »
Yes you can, but no i don't.
TFNcap
Post by TFNcap »
smyers119 wrote: 10 May 2020 17:04 Yes you can, but no i don't.
you are very kind
okay I'm on the right track
do I have to choose one of these
Outbound mail relay - outbound smarthost
I have read a few topics in the forum, but whatever is working, I do not understand clearly
I want to send e-mail from efa
eFa-4.0.2 - ©
smyers119
Post by smyers119 »
It's not so much from, but through. Yes you would need to configure it as a outbound relay, Unfortunately because I don't use it as such, I am not knowledgable with specifics. But when i get back to work on monday I can look into it.
ajmind
Post by ajmind »
TFNcap wrote: 10 May 2020 18:17 Outbound mail relay - outbound smarthost
Depending want you want to archive you could send e-mail from efa directly you do not need to specify an outbound smarthost. We do use it as we do not send directly the e-mails to the e-mail servers of the destination domains. We use another e-mailserver (from our webhoster) to send the e-mails out. If you operate your efa box not with a permanent IP-address you should consider this option too. (Otherwise you might be handled like a spammer.)
If your efa box is receiving e-mails from other internal MTAs (email-servers) to be forwarded outside, then you could specify under the option outbound mail relay, who is allowed to use efa within your network. We have specified several other MTAs with their IP address within our networks.
Mail settings
1) Outbound mail relay
2) Outbound smarthost
I'm confused. What do you want to do exactly?
Do you want mail to route the following way?
[internal mail server] <-> [EFA] <-> [outside world]
If so, that should be very easy.
TFNcap
Post by TFNcap »
pdwalker wrote: 12 May 2020 09:27 I'm confused. What do you want to do exactly?
yes this is what i want
but I relay from the internal email server to efa and I get this error
efa reject main email server
why refuses
Is something missing?
eFa-4.0.2 - ©
Did you configure your "Outbound mail relay" settings in the EFA Configuration program?
That would be under Mail Settings, Outbound mail relay
For hosts, configure it to the ip address of your [internal mail server] or to the network address of your internal network if you have multiple machines sending mail through EFA. e.g. 192.168.1.1/24
Then EFA will allow you to use it as a relay.
TFNcap
Post by TFNcap »
pdwalker wrote: 14 May 2020 09:35 Did you configure your "Outbound mail relay" settings in the EFA Configuration program?
relay:ip : 25
I got an error because I used port 587
The problem went away when I made port 25
ty all
eFa-4.0.2 - ©
ah.
I wouldn't have suspected that. Thanks for telling us your solution.
