Cron job are not running
Posted: 29 Apr 2020 09:07
by jamerson
Dear all,
the below keeps happening however the box is connect online and able to ping the internet,
emails arrives and send out over the efa, connection is correct.
any suggestions what could be the cause?
/etc/cron.hourly/0yum-hourly.cron:
Could not get metalink https://mirrors.fedoraproject.org/metalink?repo=epel-7&arch=x86_64&infra=stock&content=centos error was
12: Timeout on https://mirrors.fedoraproject.org/metalink?repo=epel-7&arch=x86_64&infra=stock&content=centos: (28, 'Operation timed out after 30001 milliseconds with 0 out of 0 bytes received')
Re: Cron job are not running
Posted: 29 Apr 2020 12:35
by smyers119
Are you able to resolve dns?
Posted: 29 Apr 2020 17:02
by Glaster
I have the same problem.
Since 2020/04/26 I daily receive email from E.F.A. with text:
14: curl#6 - "Could not resolve host: mirrors.fedoraproject.org; Unknown error"
DNS resolve working correctly.
Posted: 01 May 2020 07:50
by Pukkeltje
I have an equal problem:
Could not get metalink https://mirrors.fedoraproject.org/metal ... ent=centos error was
14: curl
Posted: 01 May 2020 13:28
If you are having trouble and can't run a yum update yourself, you need to troubleshoot your networking and dns.
Posted: 02 May 2020 13:18
by jamerson
i beleive i ve found the issue,
if you guys using IPV6 on the network settings, make sure you disable it.
somehow its perefer to use IPV6.
ive done that and the issue is gone somehow.
Posted: 04 May 2020 12:47
by ajmind
I am getting a different error message since my recently perfomed upgrade hourly:
Traceback (most recent call last):
  File "/usr/sbin/yum-cron", line 7, in <module>
    import yum
  File "/usr/lib/python2.7/site-packages/yum/__init__.py", line 59, in <module>
    import config
  File "/usr/lib/python2.7/site-packages/yum/config.py", line 30, in <module>
    from parser import ConfigPreProcessor, varReplace
  File "/usr/lib/python2.7/site-packages/yum/parser.py", line 4, in <module>
    import urlgrabber
  File "/usr/lib/python2.7/site-packages/urlgrabber/__init__.py", line 55, in <module>
    from grabber import urlgrab, urlopen, urlread
  File "/usr/lib/python2.7/site-packages/urlgrabber/grabber.py", line 550, in <module>
    import pycurl
ImportError: /usr/lib64/python2.7/site-packages/pycurl.so: undefined symbol: CRYPTO_num_locks
How to solve this as it is not related to DNS or networking?
Posted: 04 May 2020 12:57
by smyers119
What did you do to cause this? IT didn't just happen on it's own. Your probably better off reinstalling eFa.
post output of
 ldd /usr/lib64/python2.7/site-packages/pycurl.so
This is what it should look like:
[uder@host ~]$ ldd /usr/lib64/python2.7/site-packages/pycurl.so
        linux-vdso.so.1 =>  (0x00007fffadd39000)
        libcurl.so.4 => /lib64/libcurl.so.4 (0x00007fc987eb1000)
        libpython2.7.so.1.0 => /lib64/libpython2.7.so.1.0 (0x00007fc987ae5000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fc9878c9000)
        libc.so.6 => /lib64/libc.so.6 (0x00007fc9874fb000)
        libidn.so.11 => /lib64/libidn.so.11 (0x00007fc9872c8000)
        libssh2.so.1 => /lib64/libssh2.so.1 (0x00007fc98709b000)
        libssl3.so => /lib64/libssl3.so (0x00007fc986e42000)
        libsmime3.so => /lib64/libsmime3.so (0x00007fc986c1a000)
        libnss3.so => /lib64/libnss3.so (0x00007fc9868eb000)
        libnssutil3.so => /lib64/libnssutil3.so (0x00007fc9866bb000)
        libplds4.so => /lib64/libplds4.so (0x00007fc9864b7000)
        libplc4.so => /lib64/libplc4.so (0x00007fc9862b2000)
        libnspr4.so => /lib64/libnspr4.so (0x00007fc986074000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007fc985e70000)
        libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007fc985c23000)
        libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007fc98593a000)
        libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007fc985707000)
        libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007fc985503000)
        liblber-2.4.so.2 => /lib64/liblber-2.4.so.2 (0x00007fc9852f4000)
        libldap-2.4.so.2 => /lib64/libldap-2.4.so.2 (0x00007fc98509f000)
        libz.so.1 => /lib64/libz.so.1 (0x00007fc984e89000)
        libutil.so.1 => /lib64/libutil.so.1 (0x00007fc984c86000)
        libm.so.6 => /lib64/libm.so.6 (0x00007fc984984000)
        /lib64/ld-linux-x86-64.so.2 (0x00007fc98832c000)
        libssl.so.10 => /lib64/libssl.so.10 (0x00007fc984712000)
        libcrypto.so.10 => /lib64/libcrypto.so.10 (0x00007fc9842af000)
        librt.so.1 => /lib64/librt.so.1 (0x00007fc9840a7000)
        libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007fc983e97000)
        libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007fc983c93000)
        libresolv.so.2 => /lib64/libresolv.so.2 (0x00007fc983a79000)
        libsasl2.so.3 => /lib64/libsasl2.so.3 (0x00007fc98385c000)
        libselinux.so.1 => /lib64/libselinux.so.1 (0x00007fc983635000)
        libcrypt.so.1 => /lib64/libcrypt.so.1 (0x00007fc9833fe000)
        libpcre.so.1 => /lib64/libpcre.so.1 (0x00007fc98319c000)
        libfreebl3.so => /lib64/libfreebl3.so (0x00007fc982f99000)
Posted: 04 May 2020 14:43
by ajmind
It started with installing Sophos AV as mentioned here in an howto:
MAILGW1 admin]# ldd /usr/lib64/python2.7/site-packages/pycurl.so
        linux-vdso.so.1 =>  (0x00007ffdb6764000)
        libcurl.so.4 => /opt/sophos-av/lib64/libcurl.so.4 (0x00007f376e733000)
        libpython2.7.so.1.0 => /lib64/libpython2.7.so.1.0 (0x00007f376e367000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f376e14b000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f376dd7d000)
        libssl.so.1.1 => /opt/sophos-av/lib64/libssl.so.1.1 (0x00007f376dae3000)
        libcrypto.so.1.1 => /opt/sophos-av/lib64/libcrypto.so.1.1 (0x00007f376d5f3000)
        libz.so.1 => /opt/sophos-av/lib64/libz.so.1 (0x00007f376d3da000)
        librt.so.1 => /lib64/librt.so.1 (0x00007f376d1d2000)
        libssp.so.0 => /opt/sophos-av/lib64/libssp.so.0 (0x00007f376cfd0000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f376cdcc000)
        libutil.so.1 => /lib64/libutil.so.1 (0x00007f376cbc9000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f376c8c7000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f376ebba000)
Initally I was using only ClamAV.
If I run yum manually the error was solved by creating a symlink, but unfortunatly for cron it is not vailid.
Posted: 04 May 2020 14:58
by smyers119
I use sophos av without problems. Whats the link to the directions you followed? I'll look and see if maybe I can reverse engineer where it went wrong.
Posted: 04 May 2020 15:06
by ajmind
I have followd this posting not unattended but maually step by step.
It was working without a problem but after a yum update, these cron job errors have appeared.
viewtopic.php?f=19&t=3394&p=14987&hilit=sophos#p13689
Posted: 04 May 2020 15:11
by smyers119
what's output of
cat /etc/ld.so.conf
Posted: 04 May 2020 15:16
by ajmind
1MAILGW1 site-packages]# cat /etc/ld.so.conf
include ld.so.conf.d/*.conf
Posted: 04 May 2020 15:42
by smyers119
ajmind wrote: 04 May 2020 15:16
Seems you tried setting up sophosavi at some point as well.
you need to delete
from /etc/ld.so.conf
then run
sudo ldconfig
Posted: 04 May 2020 15:56
by ajmind
You are right! :clap:
I was trying according this post to use sophosavi instead of sophos:
viewtopic.php?f=14&t=3506&p=13954&hilit=savi#p13939
but I could not finish it... I do not remember why?
Two weeks of holiday and everycthing is gone... :?: I am getting too old for things like that... :think:
Posted: 05 May 2020 09:16
by ajmind
If someone tries to use sophosavi instead of sophos av he would run in this problem again.
I wonder if a working solution for that usecase is also known?
Posted: 22 May 2020 05:37
by keysteal
I am also experiencing this problem. In addition, during the night, EFA sends the quarantine report randomly not at the same time, beyond what is specified in the scheduled time.
IPV6 is disabled.
Posted: 05 Jun 2020 18:09
by chrisbruce
I am also having this issue. I think it might have something to do with some bad "Fedora project" mirrors that are being referenced in the Recursive DNS lookup.
How do I run an update on the local Fedora mirrors cache?
Am I think about this correctly?
Note the middle ping failure. :think:
[h****h@EFA ~]$ ping mirrors.fedoraproject.org
PING wildcard.fedoraproject.org (209.132.181.15) 56(84) bytes of data.
64 bytes from proxy10.fedoraproject.org (209.132.181.15): icmp_seq=1 ttl=49 time=43.9 ms
64 bytes from proxy10.fedoraproject.org (209.132.181.15): icmp_seq=9 ttl=49 time=13.4 ms
^C
--- wildcard.fedoraproject.org ping statistics ---
9 packets transmitted, 9 received, 0% packet loss, time 10174ms
rtt min/avg/max/mdev = 13.398/17.448/43.980/9.413 ms
>>>>ping: mirrors.fedoraproject.org: Name or service not known
PING wildcard.fedoraproject.org (152.19.134.142) 56(84) bytes of data.
64 bytes from vm3.fedora.ibiblio.org (152.19.134.142): icmp_seq=1 ttl=46 time=67.6 ms
64 bytes from vm3.fedora.ibiblio.org (152.19.134.142): icmp_seq=6 ttl=46 time=71.0 ms
^C
6 packets transmitted, 6 received, 0% packet loss, time 9896ms
rtt min/avg/max/mdev = 67.405/68.084/71.086/1.361 ms
Posted: 05 Jul 2020 10:42
by fakhar.khan
I do have the same issue, but fix with the following method
1. Disable IPv6
2. Check DNS setting.
After that, all done at my end with this solution.
