I am in the planning stage of a High Availability Deployment. Just wanted to start a thread to get input on it. I am going for a ( master / slave ) ( active / inactive ) type of deployment.
KeepAlived - for Virtual IP and determining master /slave
MySQL replication (Active / Active) - should cover mailwatch settings and bayes database
Rsync - should cover the mail and the mail queues.
Am i missing anything?
HA Deployment
Re: HA Deployment
Have fun, here you go.Some of my dev notes.
Some notes for development
eFa cluster setup notes
define('RPC_ALLOWED_CLIENTS', '<othernodeips>');
define('RPC_PORT', 443);
define('RPC_SSL', true);
Firewalling notes
firewall-cmd –permanent –add-service=mysql
firewall-cmd –add-port={3306/tcp,4567/tcp,4568/tcp,4444/tcp} –permanent
firewall-cmd –reload
Slave notes
grant all privileges on mailscanner.* to 'mailwatch'@'10.3.1.22' identified by 'eFaPr0j3ct' with grant option;
grant all privileges on sa_bayes.* to 'sa_user'@'10.3.1.22' identified by 'eFaPr0j3ct' with grant option;
grant all privileges on sqlgrey.* to 'sqlgrey'@'10.3.1.22' identified by 'eFaPr0j3ct' with grant option;
grant all privileges on efa.* to 'efa'@'10.3.1.22' identified by 'eFaPr0j3ct' with grant option;
flush privileges;
On slave
/etc/sqlgrey/sqlgrey.conf db_host = 10.3.1.21
/var/www/html/mailscanner/conf.php define('DB_HOST', '10.3.1.21');
/etc/MailScanner/spamassassin.conf
bayes_sql_dsn DBI:mysql:sa_bayes:10.3.1.21
user_awl_dsn DBI:mysql:sa_bayes:10.3.1.21
/usr/share/MailScanner/perl/custom/CustomAction.pm
my($db_host) = '10.3.1.21';
/usr/share/MailScanner/perl/custom/MailWatch.pm
my ($db_host) = '10.3.1.21';
/usr/share/MailScanner/perl/custom/SQLBlackWhiteList.pm
define('RPC_ALLOWED_CLIENTS', '10.3.1.21');
systemctl stop mariadb
systemctl disable mariadb
service mailscanner restart
service sqlgrey restart
Galera Multi-Master Notes
Install MariaDB 10x prior to eFa install
/etc/yum.repos.d/mariadb.repo
[mariadb]
name = MariaDB
baseurl = http://yum.mariadb.org/10.1/centos7-amd64
gpgkey=https://yum.mariadb.org/RPM-GPG-KEY-MariaDB
gpgcheck=1
yum -y update MariaDB-server MariaDB-client MariaDB-compat galera socat jemalloc
yum -y install eFa
run init scripts
Note: selinux not tuned for galera (todo), must turn off for now
Create galera configuration on frontend1
[galera]
wsrep_on=ON
wsrep_provider=/usr/lib64/galera/libgalera_smm.so
wsrep_cluster_address='gcomm:10.3.1.21,10.3.1.22' wsrep_cluster_name='galera' wsrep_node_address='10.3.1.21' wsrep_node_name='frontend1' wsrep_sst_method=rsync binlog_format=row default_storage_engine=InnoDB innodb_autoinc_lock_mode=2 bind-address=0.0.0.0 systemctl stop mariadb galera_new_cluster Create galera configuration on node2 [galera] wsrep_on=ON wsrep_provider=/usr/lib64/galera/libgalera_smm.so wsrep_cluster_address='gcomm:10.3.1.21,10.3.1.22'
wsrep_node_address='10.3.1.22'
wsrep_node_name='frontend2'
binlog_format=row
systemctl restart mariadb
Firewalling notes
Slave notes
flush privileges;
On slave
[mariadb]
name = MariaDB
gpgcheck=1
yum -y install eFa
run init scripts
[galera]
wsrep_on=ON
binlog_format=row
Re: HA Deployment
Wow that will save a lot of time, thank you very much.
