URI DNS blocklist
Posted: 17 Apr 2020 16:15
by smyers119
Does eFa take advantage of
to keep down the number of uribl queries? If not can we add a feature request for this. Maybe even a mailwatch editable list for easy updates.
Re: URI DNS blocklist
Posted: 17 Apr 2020 16:40
by smyers119
I ended up using the script in this post, It's a better then a static list, works on 4.0.2 with little modification
viewtopic.php?f=14&t=3591&p=14150&hilit=uribl#p14150
Posted: 17 Apr 2020 17:40
by jogomes
Hi, would be grateful, if you post the 'litle modification'.
Thank you and stay safe and well.
JG
Posted: 17 Apr 2020 18:59
by smyers119
Here's a copy of the working script for eFa 4.0.2
# uriskip.sh
#Originial script by forum user: nicola.piazzi
# This script is useful to create an exclusion file for uri search
# Uri search is very expensive and lots of external uribl services allow limited queries
# This script can be scheduled in cron and refresh a .cf file that exclude most used domains
# this limit dns queries number, this script check rbl before exclude
# Put it into /etc/eFa/ and put it in cron, the script restart mailscanner at the end
# 01 02 * * 0 /etc/eFa/uriskip.sh
# Parameters
ROOTPWD=$(grep MYSQLROOTPWD /etc/eFa/MySQL-Config | sed 's/.*://')
VCF=/etc/mail/spamassassin/uriskip.cf # Exclusion file fullpath
VDIRECTIVE=uridnsbl_skip_domain # Eclusion directive
VDOMINLINE=5 # Domain to exclude on each line of file
VSCANLOGDAYS=2 # Numbers of days old to scan maillog table headers
VEXCLUDENUM=200 # Number of domains to exclude, they are sorted by maximum hits
# Uri rbl to check for and left part of return code
VURICHECKS="dbl.spamhaus.org 127.0.1\
uribl.abuse.ro 127.0.0\
hostkarma.junkemailfilter.com 127.0.0.2\
hostkarma.junkemailfilter.com 127.0.0.4\
mailsl.dnsbl.rjek.com 127.0.0.2\
urlsl.dnsbl.rjek.com 127.0.0.2\
fresh.spameatingmonkey.net 127.0.0.2\
uribl.spfbl.net 127.0.0.2\
uribl.spfbl.net 127.0.0.3\
multi.surbl.org 127.0.0\
uribl.swinog.ch 127.0.0.2\
rhsbl.zapbl.net 127.0.0.2\
multi.uribl.com 127.0.0.2\
multi.uribl.com 127.0.0.4\
multi.uribl.com 127.0.0.8\
# My domains that allow
VURIFIXED="your.static.domain\
gmail.com\
VPUTURIFIXED=s # Put VURIFIXED (s/n), usually they are included because are found
VRELOADMS=s # Restart MailScanner at the end
VRELOADMSCMD="service MailScanner restart" # Restart MailScanner command
# Date & Time
NOW=$(date +"%m-%d-%Y %r")
start=`date +%s.%N`
# Drop table commented (only for testing purpose)
#C="DROP TABLE uriskip ;"
#mysql -N -u root -p$ROOTPWD -D mailscanner -se "$C"
# Create Table uriskip if not exist
C="CREATE TABLE IF NOT EXISTS uriskip (ts DATETIME default null, \
domain VARCHAR(63), domaincnt INTEGER, domainlisted INTEGER, PRIMARY KEY domain_key (domain) ) ENGINE = MyISAM; "
# Delete elements from table uriskip
C="DELETE FROM uriskip; "
# Cycle on headers of table mailscanner and insert into table uriskip counting occurrences
c=0
S="SELECT headers FROM maillog WHERE timestamp > DATE_SUB(CURDATE(), INTERVAL $VSCANLOGDAYS DAY); "
mysql -N -u root -p$ROOTPWD -D mailscanner -se "$S" | ( while read -r headers
do
((c++))
#echo $c
#echo $headers
echo $headers | while IFS='\ ;><' read -ra linearray
do
for element in "${linearray[@]}"
do :
# Scan all elements
#echo "> $element"
# Search domain
dmone=$(echo $element | grep -E -o "[\/|\.|\@][A-Za-z0-9.-]+\.[A-Za-z]{2,6}")
# Go on only if have a value
if [ -n "$dmone" ]; then
# Clean first char from domain found
dmone="${dmone:1}"
# Extract second level domain
dmtwo=$(echo $dmone | grep -E -o "[a-zA-Z0-9_-]+\.\w+$")
if [ -n "$dmtwo" ]; then
# Lowercase dmtwo
dmtwo=${dmtwo,,}
#echo $dmtwo
# Insert domain in table uriskip and if exist increment cnt
S="INSERT INTO uriskip (domain, domaincnt, domainlisted) VALUES ('$dmtwo', 1, 0) ON DUPLICATE KEY UPDATE domaincnt = domaincnt + 1; "
fi
fi
done
done
done
# Load URICHECKS arrays
declare -a vuriserver
declare -a vuricode
x=0;xx=0
for w in $VURICHECKS; do
if [[ $((x % 2)) -eq 0 ]]; then
vuriserver[xx]=$w
else
vuricode[xx]=$w; ((xx++))
fi; ((x++))
done; ((xx--))
echo "List of uribl lists to check and part of return code to match"
for y in $(eval echo {0..$xx}); do
echo $y ${vuriserver[y]} echo ${vuricode[y]}
done
echo ""
# Cycle on uriskip table to query uribls and update hit flag, we do it only for entries that will be used
c=0;
S="SELECT domain, domainlisted FROM uriskip ORDER BY domaincnt DESC; "
mysql -N -u root -p$ROOTPWD -D mailscanner -se "$S" | ( while read -r domain domainlisted
do
echo "";echo $c "Testing domain $domain"
wlisted=0;x=0
# Loop on uribl list to test given return code
#echo $y ${vuriserver[y]} echo ${vuricode[y]}
#echo "Testing on $domain.${vuriserver[y]} ${vuricode[y]}"
r=$(dig +short "$domain.${vuriserver[y]}"| grep ${vuricode[y]})
if [ ! -z $r ] ; then
((wlisted++))
echo $domain.${vuriserver[y]} $r
fi
done
# Add counter if not listed and excit on VEXCLUDENUM reached
if [ $wlisted -eq 0 ] ; then ((c++)); fi
if [ $c -gt $VEXCLUDENUM ] ; then exit 1; fi
# Insert / update domain in table uriskip
U="UPDATE uriskip SET domainlisted = $wlisted WHERE domain = '$domain'; "
mysql -N -u root -p$ROOTPWD -D mailscanner -se "$U"
#sleep 1
done
# Initialize cf file
echo "# Exclusion file for uri dns check" > $VCF
echo "# Generated by $0 on $(date)" >> $VCF
echo "" >> $VCF
chmod 775 $VCF
chown postfix:postfix $VCF
# Cycle on mydomain, if selected
if [ $VPUTURIFIXED == "s" ]; then
i=0;wrline="$VDIRECTIVE"
for domain in $VURIFIXED;do
#echo "$domain"
((i++))
wrline="$wrline $domain"
if [ $i -ge $VDOMINLINE ] ; then
echo $wrline >> $VCF
fi
done
if [ $i -gt 0 ] ; then echo $wrline >> $VCF; fi
fi
# Cycle on uriskip and create cf exclusion file for domain with hit flag 0
S="SELECT domain FROM uriskip WHERE domainlisted = 0 ORDER BY domaincnt DESC LIMIT $VEXCLUDENUM; "
do
#echo "$domain"
((i++))
fi
done
# Reload mailscanner if selected
if [ $VRELOADMS == "s" ] ; then
$VRELOADMSCMD
fi
# Logging
end=`date +%s.%N`
runtime="$(bc <<<"$end-$start")"
echo "time elapsed: $runtime sec."
Posted: 20 Apr 2020 09:17
by jogomes
smyers119 wrote: 17 Apr 2020 18:59
Thank you so much.
Cheers.
JG
Posted: 09 Jun 2020 16:59
by keysteal
But are we sure that this script works?
Posted: 10 Jun 2020 23:31
by smyers119
keysteal wrote: 09 Jun 2020 16:59
Yes it does. Works great.
