Cannot Edit MailScanner Rulesets
gtao725
Post by gtao725 »
Hello Community,
Does anyone have the same issue as I am having on the latest eFa 4.0.2? I cannot seem to edit any MailScanner Rulesets. Even after giving chmod 777 permissions to the ruleset files didnt help. Pls see attachments. Any help would be greatly appreciated. Thx in advance!
gtao725
Re: Cannot Edit MailScanner Rulesets
Post by gtao725 »
Hello Community,
I did find this viewtopic.php?t=1973 but according to the post this issue was supposed to have been fixed already and I am using the default en webgui of efa 4.0.2.
gtao725
Post by gtao725 »
Checked the /var/log/php-fpm/www-error.log and found some errors when executing php scripts from the MSRE rule edit page. Is there a solution to this?
Good 'ole permissions. Taking a look...
gtao725
Post by gtao725 »
Thx for making it an issue to be fixed on github. Guess I will use cli to make all the rules for the time being.
sergiupapuc
Post by sergiupapuc »
I have the same error with actual version! ...automatic update are on...
Can you give us a little more detail please?
sergiupapuc
...exactly like in the start of this post, but on uptodate sistem!
