Root sends email with incorrect domain
Stuart
Post by Stuart »
When root sends an email it fails because it adds the host name to the Domain, as below;
----Queue ID----- --Size-- ---Arrival Time---- --Sender/Recipient------
48WfQk25YvzB6xjb      8523 Tue Mar  3 11:22:04 root@hostname.domain.com
(host mail.targetdomain.com[1.1.1.1] said: 450 4.1.8 : Sender address rejected: Domain not found (in reply to RCPT TO command))
                                               user@targetdomain.com
Obviously the email address should be root@domain.com.
I can not seem to find where I can change this. Can any one help?
Stuart
Re: Root sends email with incorrect domain
Do you have the following file?
/etc/postfix/sender_canonical
root@example.org root@hostname.example.org
/etc/postfix/sender_canonical.db
/etc/postfix/main.cf
sender_canonical_maps = hash:/etc/postfix/sender_canonical
Stuart
Post by Stuart »
That helped. Thank you very much!
