In WEB GUI - Quarantine tab not filtering properly
henrygmail
Post by henrygmail »
I installed a new copy of efa 4.0.2 yesterday in my vm 6.5 environment. All Mail is processing as expected. :)
There is an issue with the quarantine tab. It shows all messages, spam, clean, whitelisted etc. where it should be just the spam items. Attached is a screenshot. Any suggestions would be appreciated.
Software Versions:
MailWatch Version: 1.2.15
Postfix Version: 3.4.8
MailScanner Version: 5.2.2
ClamAV Version: 0.101.5
SpamAssassin Version: 3.4.4
PHP Version: 7.2.27
MySQL Version: 10.1.41-MariaDB
GeoIP Database Version: GeoLite2 Country database 2020-02-25 08:43:01
Re: In WEB GUI - Quarantine tab not filtering properly
Quarantine tab doesn't filter, because a copy of all mail is copied to the quarantine by default. Use Search and Reports to filter further.
henrygmail
Thank you for the reply. Great product that has gotten better with 4.x
I thought I might has set something incorrectly. - Quarantine must have changed from 3.x version and now in 4.x all messages inducing items not just the quarantined go to quarantine tab.
alexanderbrix
Post by alexanderbrix »
In EFA 3.x all mails had been shown in Quarantine tab too
as long as you set your EFA installation to save a copy of the messages, I believe.
