Selinux with New kickstart install on Centos minimal
Just did a new efa kickstart install on Centos-minimal. Can confirm the razor issues are gone :clap:
On the ' old' efa4 there was spamassassin-3.4.4.rc1, on the new efa4 is spamassassin-3.4.4
The new efa is just a test to check. There are only 3 mails present, the quarantine report and 2 [SAV-LINUX] Notice from Sophos Anti-Virus mails
I installed bacula-client as additional package.
ausearch -m 'AVC' --raw | audit2allow -M my-newefa
my-newefa.te
module my-newefa 1.0;
require {
        type mscan_t;
        type admin_home_t;
        type bacula_var_run_t;
        type usr_t;
        type spamd_update_t;
        type httpd_sys_script_t;
        type dovecot_auth_t;
        type postfix_local_t;
        type bacula_t;
        class sock_file write;
        class dir { add_name getattr write };
#============= bacula_t ==============
allow bacula_t bacula_var_run_t:dir write;
#============= httpd_sys_script_t ==============
allow httpd_sys_script_t bacula_t:dir getattr;
allow httpd_sys_script_t dovecot_auth_t:dir getattr;
allow httpd_sys_script_t postfix_local_t:dir getattr;
#!!!! WARNING: 'usr_t' is a base type.
allow httpd_sys_script_t usr_t:sock_file write;
#============= mscan_t ==============
#!!!! This avc is allowed in the current policy
allow mscan_t usr_t:sock_file write;
#============= spamd_update_t ==============
allow spamd_update_t admin_home_t:dir add_name;
Re: Selinux with New kickstart install on Centos minimal
3.4.4-rc1 and 3.4.4 are the same. Just a small naming mishap in the testing repo. I should have placed the rc1 on the release and not the version.
