Update to 4.0.2
gregecslo
Update to 4.0.2
Post by gregecslo »
Hello.
I tried and failed:
Error: Package: 1:eFa-4.0.2-5.eFa.el7.x86_64 (eFa4)
Requires: MailScanner >= 5.2.2-1
Available: MailScanner-5.1.4-1.efa.3.rhel.noarch (eFa4)
MailScanner = 5.1.4-1.efa.3.rhel
Installing: MailScanner-5.1.4-1.efa.3.rhel.noarch (eFa4)
Re: Update to 4.0.2
Try again in a bit, the mirrors are replicating.
bikertrash
Re: Update to 4.0.2
Post by bikertrash »
Getting the same error this morning since 04:30 PST and still at 08:15 PST... will let it ride until tomorrow morning and see what happens.
Not too worried about though... I'm sure it'll catch up at some point. :)
Re: Update to 4.0.2
yeah the US/Canada mirror is lagging behind. It'll catch up sometime today.
Re: Update to 4.0.2
I forced an rsync. They should be in sync now. Stupid cron job...
gregecslo
Re: Update to 4.0.2
Post by gregecslo »
Hello.
I just removed mirrors from repo and it went OK.
Now I have problem that bayes score is not displayed in mailwatch gui.
Bayes DB seems OK, SA lint test went trough OK, but bayes score is not displayed at all.
Any idea?
Re: Update to 4.0.2
gregecslo wrote: 09 Feb 2020 06:12 Hello.
Any idea?
Got a screenshot you could share?
gregecslo
Re: Update to 4.0.2
Post by gregecslo »
Sure here.
Re: Update to 4.0.2
Can you run an SA Lint for me and post the output?
gregecslo
Re: Update to 4.0.2
Post by gregecslo »
Bayes is missing.
Also I have SPF_FAIL custom score set to add 5.0 points.
And in other case where I actually got mail with failed SPF it was scored + 0.95 points.
It`s like the prefs file was not evaluated or used at all.
Lint tests:
both_lint_tests.7z
(16.75 KiB) Downloaded 734 times
Also byes DB seems quite OK:
I really don`t know what went wrong here :)
Re: Update to 4.0.2
Can you post the path to your prefs file for me please?
Re: Update to 4.0.2
Also, can you verify that /etc/mail/spamassassin/MailScanner.conf is symlinked to /etc/MailScanner/spamassassin.conf?
gregecslo
Re: Update to 4.0.2
Post by gregecslo »
Prefs are here, default ones:
[root@as MailScanner]# ls -l
total 724
-rw-r--r--  1 root root    200 Feb  8 16:52 archives.filename.rules
-rw-r--r--  1 root root     13 Feb  8 16:52 archives.filename.rules.allowall.conf
-rw-r--r--  1 root root   7337 Jan 20 00:44 archives.filename.rules.conf
-rw-r--r--  1 root root    200 Feb  8 16:52 archives.filetype.rules
-rw-r--r--  1 root root     15 Feb  8 16:52 archives.filetype.rules.allowall.conf
-rw-r--r--  1 root root   1398 Jan 20 00:44 archives.filetype.rules.conf
drwxr-xr-x. 2 root root     20 Feb  9 12:41 conf.d
-rw-r--r--  1 root root  44134 Jan 20 00:44 country.domains.conf
lrwxrwxrwx. 1 root root     34 Nov 21 10:41 custom -> /usr/share/MailScanner/perl/custom
-rw-r--r--  1 root root   4331 Nov 22 17:13 defaults
-rw-r--r--. 1 root root   4330 Nov 21 10:41 defaults.v3
-rw-r--r--. 1 root root    251 Nov 21 10:41 filename.rules
-rw-r--r--. 1 root root     13 Nov 21 10:41 filename.rules.allowall.conf
-rw-r--r--. 1 root root     46 Nov 21 10:41 filename.rules-allow.conf
-rw-r--r--  1 root root   8120 Jan 18 11:08 filename.rules.conf
-rw-r--r--. 1 root root     45 Nov 21 10:41 filename.rules-deny.conf
-rw-r--r--. 1 root root    117 Nov 21 10:41 filetype.rules
-rw-r--r--. 1 root root     13 Nov 21 10:41 filetype.rules.allowall.conf
-rw-r--r--. 1 root root   1608 Nov 21 10:41 filetype.rules.conf
-rw-r--r--  1 root root 151284 Feb  8 17:25 MailScanner.conf
drwxr-xr-x. 2 root root    184 Feb  8 16:51 mcp
-rw-r--r--. 1 root root     41 Nov 21 10:41 numeric.phishing.rules
-rw-r--r--  1 root root 102413 Feb  9 08:05 phishing.bad.sites.conf
-rw-r--r--  1 root root 102213 Feb  9 08:05 phishing.bad.sites.conf.master
-rw-r--r--. 1 root root 102213 Feb  9 08:05 phishing.bad.sites.conf.master.backup
-rw-r--r--. 1 root root    200 Nov 21 10:41 phishing.bad.sites.custom
-rw-r--r--  1 root root  22249 Feb  9 08:05 phishing.safe.sites.conf
-rw-r--r--  1 root root  22046 Feb  9 08:05 phishing.safe.sites.conf.master
-rw-r--r--. 1 root root  22046 Feb  9 08:05 phishing.safe.sites.conf.master.backup
-rw-r--r--. 1 root root    203 Nov 21 10:41 phishing.safe.sites.custom
lrwxrwxrwx  1 root root     30 Feb  8 16:52 reports -> /usr/share/MailScanner/reports
drwxr-xr-x. 2 root root   4096 Feb  8 16:52 rules
-rw-r--r--  1 root root  12720 Feb  8 16:52 spamassassin.conf
-rw-r--r--. 1 root root  12366 Nov 21 10:37 spamassassin.conf.bak
-rw-r--r--. 1 root root  12370 Nov 21 10:41 spamassassin.conf.v3
lrwxrwxrwx. 1 root root     34 Nov 21 10:41 spam.assassin.prefs.conf -> /etc/MailScanner/spamassassin.conf
-rw-r--r--  1 root root   1129 Jan 20 00:44 spam.lists.conf
-rw-r--r--  1 root root   1684 Jan 20 00:44 virus.scanners.conf
-rw-r--r--. 1 root root   1488 Nov 21 10:41 virus.scanners.conf.v3
I have no such file in spamassassin folder:
[root@as spamassassin]# ls -l
total 44
-rw-r--r--  1 root root 1287 Feb  8 16:52 init.pre
-rw-r--r--. 1 root root 2379 Nov  4 11:51 local.cf
-rw-r--r--. 1 root root 2380 Nov 21 10:41 local.cf.v3
drwx------. 2 root root   83 Feb  9 08:05 sa-update-keys
-rw-r--r--. 1 root root 2523 Nov 21 10:11 v310.pre
-rw-r--r--. 1 root root 1194 Nov  4 11:51 v312.pre
-rw-r--r--. 1 root root 2412 Nov 21 10:11 v320.pre
-rw-r--r--. 1 root root 1237 Nov  4 11:51 v330.pre
-rw-r--r--. 1 root root 1020 Nov  4 11:51 v340.pre
-rw-r--r--. 1 root root 1303 Nov 21 10:11 v341.pre
-rw-r--r--. 1 root root 1499 Nov 21 10:11 v342.pre
-rw-r--r--  1 root root 1262 Feb  8 16:52 v343.pre
gregecslo
Re: Update to 4.0.2
Post by gregecslo »
Fixed by doing:
cd /etc/mail/spamassassin/
ln -s /etc/MailScanner/spamassassin.conf mailscanner.cf
systemctl restart mailscanner
Why symlink dissapeared?
Re: Update to 4.0.2
I see you migrated from v3. It looks like you have the old symlink still as well. Interesting.
gregecslo
Re: Update to 4.0.2
Post by gregecslo »
Yeah I did migrate.
So what is the correct symlink?
The one I just created works just fine.
Re: Update to 4.0.2
Yeah, the one you created is correct. The other one isn't hurting anything. Not sure why it disappeared, but I will migrate a v3 and update it to try to find out why.
gregecslo
Re: Update to 4.0.2
Post by gregecslo »
OK thanks.
But for info, I migrated to V4 and everything was OK.
After 4.0.1 to 4.0.2 bayes stopped working, the rest is OK.
Re: Update to 4.0.2
In that case I am going to add a condition to check for this symlink after the update. Hope this helps. ;)
gregecslo
Re: Update to 4.0.2
Post by gregecslo »
Yeah, that should do the trick :)
gregecslo
Re: Update to 4.0.2
Post by gregecslo »
Hi.
Updated to new mailscanner and efa and had to this again.
bayes was not working.
smyers119
Re: Update to 4.0.2
Post by smyers119 »
I had to do this on a brand new install of 4.0.2.
Re: Update to 4.0.2
After the upgrade today
eFa-4.0.2-13.eFa.el7.x86_64.rpm
MailScanner-5.3.1-1.eFa.3.rhel.noarch.rpm
python2-josepy-1.3.0-2.el7.noarch.rpm
I noticed that the following symbolic link was still missing:
The summary showed the following text:
To update MailScanner and necessary modules run:
/usr/sbin/ms-configure --update
The /usr/sbin/ms-configure --update will also check for the missing symlink and create it when missing.
It will take some time to complete. After that everything worked fine. :clap:
Re: Update to 4.0.2
Fixed. Next update will ensure this symlink remains present.
Re: Update to 4.0.2
Also just FYI, shouldn't need to run ms-configure. eFa dependencies are managed. If you were building your own mailscanner from scratch, then yes. I'll make a note to remove that message from the update package from upstream.
