Outgoing not monitored
hokage
Post by hokage »
Hello all..
I am trying to know how to monitoring of outgoing email
I have seen the EFA only monitor the incoming.
Any docs about this?
thx before
Re: Outgoing not monitored
Use EFA as your outgoing mail host and EFA will check your outgoing mail.
hokage
Post by hokage »
I do.
the MX using single MX to EFA. but not monitored
Maybe I am not understanding your question.
If you use EFA as your MX host, then all incoming mail will be monitored by the system.
internet -> EFA -> your actual mail server -> your users
If you use EFA as your outgoing smarthost, then all your outgoing mail will be monitored by the system.
your users -> your actual mail server -> EFA -> internet
Perhaps you can explain how your mail system is actually configured?
hokage
Post by hokage »
pdwalker wrote: 08 Feb 2020 11:05 Maybe I am not understanding your question.
solved sir. thx
What was your problem?
