NEW INSTALL EFA4 MAILWATCH EMPTY
hugorosa
Post by hugorosa »
Hello
i 've installed from scratch new server EFA4
I can send and receive email, using whitelist and blacklist but i don't have any info in Recent Messages and in Quarantine.
Just empty....
Anyone with the same problem ?
Hugo
hugorosa
Re: NEW INSTALL EFA4 MAILWATCH EMPTY
Post by hugorosa »
Did you install the Maxmind free license key to to download GeoLite2? viewtopic.php?f=8&t=4068
And you are sure that your eFa processed any mail? (as the todays counters are all zero on your screenprint)
hugorosa
Post by hugorosa »
Yes
hugorosa
Post by hugorosa »
yes i have two domains
and i can send and receive emails.
I have DKIM+DMARC+SPF installed and config+ RBL
All OK !!
The strange thing it's just the Blacklist And Whitelist Writes to MARIADB
the page it's like you can see ...empty
also if i check mysql db mailscanner table "maillog" it's empty....
The log file maillog works as expected....
Strange thing....
I have also build new VM to test.... create one domain, and the same thing....
pugh32
Post by pugh32 »
I am having exactly the same issue with a fresh install.
hugorosa
Post by hugorosa »
My solution was
Build a new Vm minimal install
And use curl ....
I think the new script it’s different and now it’s all ok
