eFa 4.0.2 testing
Posted: 06 Feb 2020 10:39
Tested the update. Works like a charm.
I would almost ask for some spam now. Almost
The issues with URILocalBL are gone.
/etc/mail/spamassassin/block.cf
dbg: config: uri_block_cc added Belgium
dbg: config: uri_block_cidr adding 65.181.64.0/18 to TiTi
dbg: config: uri_block_isp adding "COMBELL Network" to COMBELL
Just one issue with mdadm
efa4: freshclam[6568]: bytecode.cvd is up to date (version: 331, sigs: 94, f-level: 63, builder: anvilleg)
efa4: systemd: [/usr/lib/systemd/system/mdcheck_continue.service:14] Invalid environment assignment, ignoring: MDADM_CHECK_DURATION='"6 hours"'
efa4: systemd: [/usr/lib/systemd/system/mdcheck_start.service:14] Invalid environment assignment, ignoring: MDADM_CHECK_DURATION='"6 hours"'
mdadm.x86_64 4.1-1.el7 @anaconda
See: https://bugzilla.redhat.com/show_bug.cgi?id=1774354
ifplugin Mail::SpamAssassin::Plugin::URILocalBL
# Country Belgium
uri_block_cc Belgium be
#cidr
uri_block_cidr TiTi 65.181.64.0/18
#Isp
#curl -s https://www.whoismyisp.org/ip/xxx.xxx.xxx.xxx | grep -oP -m1 '(?<=isp">).*(?=</p)'
#curl -s https://www.whoismyisp.org/ip/91.230.176.139 | grep -oP -m1 '(?<=isp">).*(?=</p)'
#COMBELL Network
uri_block_isp COMBELL "COMBELL Network"
endif # Mail::SpamAssassin::Plugin::URILocalBL
spamassassin -D --lint 2>&1 | grep 'config: uri_block'dbg: config: uri_block_cidr adding 65.181.64.0/18 to TiTi
yum list installed |grep mdadmSee: https://bugzilla.redhat.com/show_bug.cgi?id=1774354
