				MaxMind GeoLite
				Posted: 02 Feb 2020 03:42
				by gdardick
				I have gotten MaxMind account info and a corresponding GeoIP.conf file for a new installation of eFA4.
Where does the GeoIP.conf file go?
				Re: MaxMind GeoLite
				Posted: 02 Feb 2020 16:20
				File not used in eFa, eFa has its own config built-in.
Add the license key using eFa-Configure
				Re: MaxMind GeoLite
				Posted: 03 Feb 2020 08:57
				by gdardick
I added the license key through eFa.
Tried to run update GeoIP Database from MailWatch and got the following...and then never finishes.
Downloading file, please wait...
Download complete, unpacking files...
Also - Software Version shows:
GeoIP Database Version: No database downloaded
				Re: MaxMind GeoLite
				Posted: 03 Feb 2020 09:49
				Take a look in the following location.
ls -l /var/www/html/mailscanner/temp
				Re: MaxMind GeoLite
				Posted: 05 Feb 2020 16:57
				by gdardick
				I did and got the following:
[root@dardickmailgw ~]# ls -l /var/www/html/mailscanner/temp
total 4
-rw-r--r--. 1 php-fpm php-fpm 20 Feb  3 04:04 GeoLite2-Country.tar.gz
-rwxrwxr-x. 1 root    php-fpm  0 Dec 27 08:04 index.html
any ideas?
				Re: MaxMind GeoLite
				Posted: 05 Feb 2020 23:17
sudo rm /var/www/html/mailscanner/temp/GeoLite2-Country.tar.gz
Give it another try.
				Re: MaxMind GeoLite
				Posted: 07 Feb 2020 09:51
				by gdardick
				same result ... still hangs
MailWatch Version: 1.2.14
Postfix Version: 3.3.0
MailScanner Version: 5.1.4
ClamAV Version: 0.101.5
SpamAssassin Version: 3.4.2
PHP Version: 7.2.26
MySQL Version: 10.1.41-MariaDB
[root@dardickmailgw ~]# sudo rm /var/www/html/mailscanner/temp/GeoLite2-Country.tar.gz
[root@dardickmailgw ~]# ls -lah /var/www/html/mailscanner/temp/
total 16K
drwxrwxr-x. 2 root    php-fpm   55 Feb  7 04:48 .
drwxr-xr-x. 7 root    root    8.0K Feb  1 17:51 ..
-rw-r--r--. 1 php-fpm php-fpm   20 Feb  7 04:48 GeoLite2-Country.tar.gz
				Re: MaxMind GeoLite
				Posted: 07 Feb 2020 10:32
				I suspect something is wrong with your Maxmind key.  Can you double check it?
				Re: MaxMind GeoLite
				Posted: 07 Feb 2020 12:37
				by gdardick
				I did check and just in case regenerated a key.
FYI - there are 2 choices when generating the key. I chose the first one (latest version of MaxMind - >= 3.1.1)
				Re: MaxMind GeoLite
				Posted: 07 Feb 2020 12:42
				by gdardick
				Just for grins, I did the following:
[root@dardickmailgw ~]# tar -tf /var/www/html/mailscanner/temp/GeoLite2-Country.tar.gz
tar: This does not look like a tar archive
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
				Re: MaxMind GeoLite
				Posted: 07 Feb 2020 12:44
				by gdardick
				hmmmm ... and then I did the following
[root@dardickmailgw ~]# cat /var/www/html/mailscanner/temp/GeoLite2-Country.tar.gz
Invalid license key
				Re: MaxMind GeoLite
				Posted: 07 Feb 2020 12:52
				by gdardick
				so I tried version < 3.1.1 and that did work.
Thanks Shawn!
One last question..hopefully.
Now what? (where/how will the data be used/viewed)
