Spamassassin parameter "trusted_networks" does not work
ManFarang
Post by ManFarang »
I'm running my own mailserver (Lotus Domino) behind a dynamic IP. DDNS works perfectly.
efa project server is up and running and normally checks/delivers mail properly.
MailWatch Version: 1.2.14
Postfix Version: 3.3.0
MailScanner Version: 5.1.4
ClamAV Version: 0.101.5
SpamAssassin Version: 3.4.2
PHP Version: 7.2.26
MySQL Version: 10.1.41-MariaDB
efa is used for incoming mail only, outbound mail is handled by Domino and has no problems.
Unfortunately my ISP (3bb in Thailand) interferes in handling port 25. So I have the following scenario:
mail from internet (port 25) -> 3bb internal SMTP checker -> efa project -> Domino server -> user mail
From time to time the ISP assigns a new external IP. And here the problem comes into play.
Very many of the dynamic IPs of 3bb are listed bei Spamhouse. And that kills the process of accepting mails by efa:
<** 554 5.7.1 Service unavailable; Client host [14.207.140.204] blocked using zen.spamhaus.org; https://www.spamhaus.org/query/ip/14.207.140.204
When this IP is checked at the Blocklist Removal Center
https://www.spamhaus.org/lookup/
most of the time the IP is listed in the PBL.
Removing the IP from this list is an easy process and takes about 30 minutes to be effective.
The problem is that all mails are rejected during the period from changing the IP and removing the IP from the PBL.
I tried to solve that problem with the following entry in /etc/mail/spamassassin/local.cf:
trusted_networks 14.207. 182.88.
(dynamic IPs are are assigned from IP-ranges like that)
But that has no effect. Spamhouse listed IPs still kill the reception of mail.
Any idea what I can do? Any errors in the logic/notation?
Help is very appreciated.
Thank you.
Re: Spamassassin parameter "trusted_networks" does not work
Did you uncomment the shortcircuit plugin block in local.cf?
ManFarang
Post by ManFarang »
no :whistle:
did that now, rebooted the machine and will see what happens
thanks for your advice :text-goodpost:
will report on that matter...
ManFarang
Post by ManFarang »
promised to report on that matter...
this night the IP changed (I didn't force the change during the last days to see what would happen).
The newly assigned one (14.207.139.61) is from the range 14.207. that I defined as a trusted_network in local.cf:
# Set which networks or hosts are considered 'trusted' by your mail
# server (i.e. not spammers)
# changes made for 3bb intermediate hosts
trusted_networks 14.207. 183.88.
# if you have taken the time to correctly specify your "trusted_networks",
# this is another good way to save CPU
shortcircuit ALL_TRUSTED on
Unfortunately that doesn't have the expected effect. Mails coming in from this IP are still considered bad by Spamhaus:
<** 554 5.7.1 Service unavailable; Client host [14.207.139.61] blocked using zen.spamhaus.org; https://www.spamhaus.org/query/ip/14.207.139.61
-> QUIT
Any ideas what to do?
Thanks for any help...
PS: this IP was in the PBL list of spamhaus (as most of the blacklisted ones) and was easily removed.
Checked MailScanner and postfix for a spamhaus entry? SA might not be doing the work here...
ManFarang
Post by ManFarang »
thanks for the hint.
But I'm a newbie on efa project and its inner workings with all the tools.
So if anybody can direct me where exactly to search...
any help is very appreciated
