sudo: /usr/sbin/eFa-Configure: command not found
Posted: 10 Jan 2020 16:24
by Alleyviper
Recent messages stopped working since 31-12-2019
Getting into console there is an erro
Re: sudo: /usr/sbin/eFa-Configure: command not found
Posted: 10 Jan 2020 19:28
by gregecslo
Yeah I also have no recent messages.
Mailflow works OK.
Have the very same error in console.
Posted: 10 Jan 2020 23:25
by jamerson
make sure your EFA is update.
we've found the issue and fixed it on the last cron job.
Posted: 11 Jan 2020 08:26
by gregecslo
Umm okay....
I did yum update and it found Mailwatch update and bunch of php updates.
Efa is still at 4.0.0
How do we update to 4.0.1 ?
I have repo added in yum repos.
After mailwatch update there are no more messages added to gui.
Also error remains: sudo: /usr/sbin/eFa-Configure: command not found
Any idea?
Posted: 11 Jan 2020 13:25
There are 2 things to keep in mind if you want to update, when using a previous efa4 build from the testing repo.
1. Change to the production repo
viewtopic.php?f=8&t=3879
2 Request a free maxind licence
viewtopic.php?f=8&t=4067
And enter the licence via the configure option screen from Efa.
Works fine
Posted: 11 Jan 2020 13:34
gregecslo wrote: 11 Jan 2020 08:26
Umm okay....
Any idea?
Please run this and report back...
Posted: 11 Jan 2020 13:35
by gregecslo
Hi.
Output:
[root@as ~]# rpm -qa | grep ^eFa
eFa-base-4.0.0-1.eFa.el7.x86_64
Posted: 11 Jan 2020 13:37
by gregecslo
I have prod repo:
[root@as ~]# cat /etc/yum.repos.d/eFa4.repo
[eFa4]
name=eFa-Project
baseurl=https://dl.efa-project.org/rpm/eFa4/x86_64
mirrorlist=https://dl.efa-project.org/rpm/eFa4/mirrors-eFa
failovermethod=priority
enabled=1
Problem is, I can`t even update to 4.0.1
Posted: 11 Jan 2020 13:49
by gregecslo
And output of yum update:
Dependencies Resolved
Package Arch Version Repository Size
Updating:
MailWatch x86_64 1:1.2.14-1.eFa.el7 eFa4 1.3 M
certbot noarch 1.0.0-1.el7 epel 41 k
microcode_ctl x86_64 2:2.1-53.7.el7_7 updates 2.5 M
mod_php72u x86_64 7.2.26-1.el7.ius ius 3.1 M
nss x86_64 3.44.0-7.el7_7 updates 854 k
nss-softokn x86_64 3.44.0-8.el7_7 updates 330 k
nss-softokn-freebl x86_64 3.44.0-8.el7_7 updates 224 k
nss-sysinit x86_64 3.44.0-7.el7_7 updates 65 k
nss-tools x86_64 3.44.0-7.el7_7 updates 528 k
nss-util x86_64 3.44.0-4.el7_7 updates 79 k
php72u-cli x86_64 7.2.26-1.el7.ius ius 4.8 M
php72u-common x86_64 7.2.26-1.el7.ius ius 1.2 M
php72u-fpm x86_64 7.2.26-1.el7.ius ius 1.6 M
php72u-gd x86_64 7.2.26-1.el7.ius ius 185 k
php72u-json x86_64 7.2.26-1.el7.ius ius 72 k
php72u-ldap x86_64 7.2.26-1.el7.ius ius 79 k
php72u-mbstring x86_64 7.2.26-1.el7.ius ius 499 k
php72u-mysqlnd x86_64 7.2.26-1.el7.ius ius 241 k
php72u-pdo x86_64 7.2.26-1.el7.ius ius 133 k
php72u-process x86_64 7.2.26-1.el7.ius ius 88 k
php72u-xml x86_64 7.2.26-1.el7.ius ius 211 k
python-requests noarch 2.6.0-8.el7_7 updates 95 k
python2-acme noarch 1.0.0-1.el7 epel 74 k
python2-certbot noarch 1.0.0-1.el7 epel 358 k
python2-certbot-apache noarch 1.0.0-1.el7 epel 107 k
tnef x86_64 1.4.18-1.el7 epel 56 k
Posted: 11 Jan 2020 13:51
Please run this:
(You are missing the update rpm for some reason)
Posted: 11 Jan 2020 13:56
by gregecslo
Just did that and it installed it and Mailwatch too.
But still on 4.0.0
[root@as ~]# sudo yum install eFa
Loaded plugins: fastestmirror
* base: mirror.easyname.at
* eFa4: dl.efa-project.org
* epel: mirror.euserv.net
* extras: mirror.easyname.at
* updates: ftp.arnes.si
Package 1:eFa-4.0.1-8.eFa.el7.x86_64 already installed and latest version
Nothing to do
[root@as ~]# yum update
No packages marked for update
by gregecslo
Posted: 11 Jan 2020 14:01
by gregecslo
--- Welcome to the eFa Configuration program ---
--- https://www.efa-project.org ---
You are currently running eFa-4.0.0.
Please choose an option:
0) Logout from ssh 9) MariaDB Recovery
1) Shell 10) Apache Settings
2) Reboot system 11) Virus Settings
3) Halt system 12) System Restore
4) IP Settings 13) Update Now
5) Tunables 14) Maintenance Mode
6) MailWatch Settings 15) Let's Encrypt
7) Mail Settings 16) DKIM and DMARC
8) Spam Settings 17) Webmin
[eFa] :
Mailwatch also says 4.0.0
And now after I just updated no more recent messages in Mailwatch
Posted: 11 Jan 2020 14:22
Anything in /var/log/eFa/update.log ?
Posted: 11 Jan 2020 14:46
by gregecslo
There is no such file.
How to update efa to 4.0.1 if coming from 4.0.0 stable anyway?
Just yum update?
BTW I have selinux disabled is this a problem?
Posted: 11 Jan 2020 14:56
Normally, yes, but your system was in a broken state for some reason. You should not have been missing the update rpm.
Let's attempt to manually fix...
wget https://raw.githubusercontent.com/E-F-A/v4/master/rpmbuild/SOURCES/eFa-4.0.1/updates/update-4.0.0.sh
sudo ./update-4.0.0.sh
wget https://raw.githubusercontent.com/E-F-A/v4/master/rpmbuild/SOURCES/eFa-4.0.1/updates/update-4.0.1.sh
sudo ./update-4.0.1.sh
If successful, please do the following to bump the version.
echo "eFa-4.0.1" > /etc/eFa-Version
Posted: 12 Jan 2020 06:40
by gregecslo
I think that did it.
First I had to:
yum install eFa
then execute update scripts and now its ok.
Don`t know why it ended up in broken state in first place.
Thanks a bunch!
