I've 3 or 4 questions :
1 - is that possible to modify (via the interface OR cli) the modify the object of a spam ?
2 - CAn i change the language of the web interface, the login is in french but the web interface is in english. I've modified the file /etc/baruwa/settings.py and the line LANGUAGE_CODE and put 'fr'. But it's always in English
BUGS
- the signatures seems won't work with EFA 0.3 ? i've created manually the folder /etc/MailScanner/signatures/domains/html/ & /etc/MailScanner/signatures/domains/txt/ But the web interface seems to be buggy !
- the Bayes information says : Bayes information could not be collected !?
Thanks for your answer.
