view content of allowed messages
cryptz
Post by cryptz »
I have efa 4 running at my house in a home lab but i do receive email for my personal domains. sometimes I perform maintenance on my storage server and as a result take my mailserver down. It looks like out of the box I cannot view message body of allowed messages in EFA. Is this configurable? I would like to read messages in the admin portal if possible.
At the moment my email servers are offline and i see messages in efa that I would love to be able to read but cannot =)
cryptz
Re: view content of allowed messages
Post by cryptz »
so just wanted to say i am home now and see its possible to view the message. is it blocked if you are remote? i am fairly confident the link to the file was not present when i was on the wan side.
Should be able to see it anywhere you have GUI access.
examine the url carefully. Is it available externally? Is it blocked by your home firewall?
cryptz
Post by cryptz »
the url is accessible remotely, i dont believe the link was displayed.
I am reviewing the efa appliance now, the links are present, even now when i am remote. Taking a step back, when i initially reported the issue my exchange server was down because i was patching the storage array.
Is it possible that a message that is deemed clean, but not able to be delivered because the destination server is down (ie queued) doesnt show up with a message path?
I believe the "path to message" field was unpopulated in that scenario.
I don't have enough information to debug your problem.
Simply put - if you can view the message internally, then you should be able to view the message externally - unless the request to pull the message view is using a non external url.
