Seems that after upgrading certbot-auto, LE no longer works.
Is there some workaround already?
The Let's Encrypt feature is already Enabled
You may update an exisiting configuration (ex. new FQDN) by disabling and then re-enabling this feature.
Would you like to Disable Let's Encrypt? [y/n/c]
y
I'm restoring the original self-signed certs back to Apache.
Done.
I've removed the monthly renewal task.
I've restored the original self-signed cert to Webmin.
httpd: no process killed
Starting httpd: httpd: Syntax error on line 212 of /etc/httpd/conf/httpd.conf: Syntax error on line 223 of /etc/httpd/conf.d/ssl.conf: Could not open configuration file /etc/letsencrypt/options-ssl-apache.conf: No such file or directory
[FAILED]
Problems with Let's Encrypt
Re: Problems with Let's Encrypt
Remove line 223 out of /etc/httpd/conf.d/ssl.conf
