Install Script - dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from
alter_igel
Post by alter_igel »
i would like to install efa on a VPS.
I get this error (Cent OS 7):
Created symlink from /etc/systemd/system/multi-user.target.wants/firewalld.service to /usr/lib/systemd/system/firewalld.service.
ERROR:dbus.proxies:Introspect error on :1.56:/org/fedoraproject/FirewallD1: dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
Error: The name :1.56 was not provided by any .service files
[eFa] - Error initializing system!  Please try again...
Thx.
Re: Install Script - dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Message recipient disconnected f
Can you post the output from the following commands?
sudo systemctl start firewalld
sudo firewall-cmd --list-all
rweedage
Post by rweedage »
My installation the same.. Firewall is not running
kommunen
Post by kommunen »
The problem seems to be in certain versions of CentOS/RHEL7.
Here's a Bugzilla report about the same problem https://bugzilla.redhat.com/show_bug.cgi?id=1575845
The quick fix appears to be
systemctl restart dbus
systemctl restart firewalld
