[SOLVED] RAM
gregecslo
[SOLVED] RAM
Post by gregecslo »
Hi all!
I have migrated from V3 to V4 yesterday.
Now I have a ram issue.
V3 had 3072MB of RAM and it worked great for 2 years.
V4 has also 3GB of RAM but I have serious problems with it.
I boot it up and it crashes and reboots in 90 seconds after startup. I figured it out that if I assign 5GB of RAM all is good.
Funny thing is, swap is not being used at all.
I have clam and sophos and that is it.
What can I do except of bumping up ram?
gregecslo
Re: RAM
Post by gregecslo »
OK solved it.
It was Sophos on-access scanner.
Whoever install Sophos should disable on access scanner OR give machine sufficient RAM:
/opt/sophos-av/bin/savconfig set EnableOnStart false
If on access starts and there is not enough RAM it crashes kernel as it won`t use swap at all.
Re: [SOLVED] RAM
:clap:
Re: [SOLVED] RAM
Did you execute a Lint check in the GUI and checked the audit.log?
grep 'avc:  denied' /var/log/audit/audit.log
I used this unattended Sophos install script viewtopic.php?t=3394
gregecslo
Re: [SOLVED] RAM
Post by gregecslo »
I`ve disabled selinux first thing after I deployed efa v4 :)
Re: [SOLVED] RAM
ahaa, disable selinux... That's what I used to do :lol:
With sellinux enabled, you just exec the script and Sophos will work like a charm.
I can confirm that Efa4 runs fine with selinux enabled (and a lot of other additional packages installed), thanks to Shawn.
Re: [SOLVED] RAM
henk wrote: 23 Nov 2019 19:42 I can confirm that Efa4 runs fine with selinux enabled (and a lot of other additional packages installed), thanks to Shawn.
Fun fact: building an selinux ruleset for eFa took over a year :ugeek:
gregecslo
Re: [SOLVED] RAM
Post by gregecslo »
Just because of that I might enable it :)
