Messages Search
rooter_c
Messages Search
Post by rooter_c »
Does it work? Mine gives me a page not found error. Is that supposed to be used to search through the archived messages? Don't fancy manually reading through 716 pages to see if an email got stuck!
darky83
Site Admin
Re: Messages Search
Post by darky83 »
The "Search" option in Baruwa 1 is not really a search function it is a message id lookup, you can only enter message id's if the message id is none existent you get a 404 message.
So the creators of the Baruwa interface did this by design.
In Baruwa 2.0 this is a full featured search option but EFA is still using 1.1.2 as I have not got baruwa 2.0 working yet (and I really don't like the way they have setup that interface...)
darky83
Site Admin
Re: Messages Search
Post by darky83 »
btw if you really want to search you can try to do so from the linux command line.
all mail is stored in: /var/spool/MailScanner/quarantine
So just do a recursive search there with grep.
